Good deal on a Sinar?
Discussion in 'Beyond the Basics' started by voodoocat, Apr 10, 2004.
  1. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    Well I met Jerry Jacka today. And I bought one of his cameras. A 4x5 Sinar. I have no idea how to figure out the model. Maybe someone can help me figure it out. Anyway. It came with 6 brand new film holders, 3 used and a 5x7 back! All for.. .drumroll please.... $275
  2. havoc
    havoc Jedi something or other
    Aug 23, 2003
    1,093
    4
    Portland Oregon, USA
    Wow, does it include a lens? Either way its a smoking deal! I would ave bought it in a heartbeat at that price. I see them on ebay from anywjere around 500-1000 dollars, usually not including lens. The Film holders are gravy considering they go on ebay in pretty banged up shape for 10-20 dollars a piece.
    The Sinar is a damn fine camera, a guy in my class uses one, his sinar is what interested my to get into LF, but i could only afford a press camera, if i saw that camera at that price though i would be more then satisfied.
  3. voodoocat
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    No lens. Those go for about 500-1000 on ebay.
    There was a newer model with the lens and tons of accessories for 850.
  4. havoc
    Aug 23, 2003
    1,093
    4
    Also not too bad of a deal. If you just wanna get started i think you can use an Ektar lens from a press camera, just have to get it to fit the lens board, and those lenses with shutter are about 80-150 dollars. I dunno Mett could prolly tell you more about that though, and if it truely is possible.
    Are your holders 4x5 or 5x7? I know the Sinar is a 4x5 camera but you can use 5x7 stuff with it. i would prolly stick with 4x5, its more mainstream, therefore cheaper and easier to find accesories. Plus i think with a 5x7 and higher you have to get a special enlarger just for LF. I know that some of the higher end 35mm enlargers will do up to 4x5 for you, i.e. Beseler 23c, Omega D series, Beseler 4x5 etc.
  5. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    You should be able to mount any lens/shutter into any lensboard, as long as it has right size hole cut. There is a handy tool for tightening the rings; I can't remember the name (maybe called a spanner?), but it's like two screwdrivers mounted on a crossbar. When tightening up the lens I usually tape a piece of cardboard over the glass, just in case the tool slips.
    I'm not all that familiar with specific Sinar models. I know they have a great reputation. Is it a monorail view camera or a field camera?
  6. voodoocat
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    ksmatt do you know anyway I might be able to figure out the model? Only thing I can find is the serial # which is 700155 and the manual i got with it has a copyright of 1967. It's in damn good shape.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  7. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    I don't know much about Sinar cameras. From a quick look around the web it appears that there are models refered to as A-1, F, F1, F2, P, P1, and P2. Maybe P is the same as P1, and F the same as F1? I couldn't find any pics to compare yours to. Several articles mentioned a modification that could be done to allow 4x5 and 5x7. There is also a model called the Norma that shoots 4x5 and 5x7. The hardware on the rail looked similar to yours, but the bellows was different.
    Try to find a Sinar users group, or just email Sinar the serial number. They should be able to tell you what model it is.
  8. voodoocat
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    Thanks for the tips. I spent hours today trying to figure it out. I guess the usergroup or email to Sinar would be the easiest way :D
sinar
sinar 4x5 view camera manual
sinar a1
sinar a1 manual
sinar a1 modification
sinar camera models
sinar mdoel comparison
sinar norma serial numbers
sinar p serial numbers
sinar serial numbers
