Good Friend of mine.
Discussion in 'Photography Beginners' Forum' started by onesix, Nov 29, 2009.
  1. onesix
    onesix TPF Noob!
    Apr 2, 2009
    53
    Colorado Springs
    Hello all... I understand that this shot does have a very harsh shadow across the face. The sun came out unexpectedly and I did not have my sun shade/filter. Is there anything I can do to fix it?
    Chris
    [​IMG]
  2. onesix
    onesix TPF Noob!
    Apr 2, 2009
    53
    Colorado Springs
    Feel free to play around with it. So I can learn... please let me what steps you took to fix it.
    Thanks
  3. KmH
    Apr 9, 2009
    38,726
    5,153
    Iowa
    Just do a little dodging on it.
    What editing software do you have?
  4. TJ K
    TJ K No longer a newbie, moving up!
    Sep 9, 2008
    2,093
    Sunny South Florida
    There wouldn't be a way to completely rid the shadows and make it look as if there was soft even lighting. Try a little bit of dodging but it won't be 100% probably. Sorry if that is what you wanted. If you can try again with better lighting and you should get better results. That smilie in your sig kept messing with me ha.
    tj
  5. photograham
    photograham TPF Noob!
    Apr 22, 2009
    93
    [​IMG]Harsh shadow but cute girl :)
  6. onesix
    onesix TPF Noob!
    Apr 2, 2009
    53
    Colorado Springs
    I'm using PS4.
  7. Wolverinepwnes
    Wolverinepwnes TPF Noob!
    Oct 28, 2009
    289
    The framing is good, its just that the picture is a little overexposed, so eithe on the camer drop the EV to like -1ish or through PP lower it!
  8. KmH
    Apr 9, 2009
    38,726
    5,153
    Iowa
    Sorry, I've never heard of PS4, unless you mean Adobe Photoshop CS4, or Photoshop Elements 4 (PSE4).
  9. TJ K
    Sep 9, 2008
    2,093
    Sunny South Florida
    Do you mean cs4?
    tj
  10. onesix
    onesix TPF Noob!
    Apr 2, 2009
    53
    Colorado Springs
    Oops... sorry... yes CS4.
  11. KmH
    Apr 9, 2009
    38,726
    5,153
    Iowa
    [​IMG]
    Being a reduced size JPEG there's not much that can be done. hopefully you have a RAW capture so the blown highlights can be recovered.
    First I opened it in ACR as a 16 bit file and played with the Recovery and Exposure sliders. Since it's not the RAW file, recovery didn't help much with the blown areas in her hair, cheeks, chin, lower neck, shoulders and arms.
    In the Photoshop work space open ed a new layer, set the blending mode to soft light and checked the box to fill the layer with 50% gray. I set the Dodge tool to Modtones, 58% and checked the "Protect Tones" box. I then dodged with a soft edged brush in the shadow areas. I then made a Curves adjustment layer and set a custom contrast curve.
    Lastly I returned the image to 8-bit mode, flattened the image, created the mat and frame, flattened again and resaved at the highest quality.
    You didn't ask for critique but the pose is not flattering. You need to make sure your subjects are sitting tall and are leaning slightly forward at the waist. Shoulders should be at about a 45 degree angle to the image sensor and their weight on the back foot if standing. When they are sitting it's nice if you can get the front foot up and get the shoulder line off level a little. Check into the 3-1-2 pose and the 2-2-1 pose. Most portraits of an individuals are done with the camera in the portrait orientation, which is how I cropped the image. Ideally, you want an eye on a rule-of-thirds or goldern ratio power point which can't be done with the landscape orientation.
  12. Aritay
    Aritay TPF Noob!
    Nov 29, 2009
    49
    [​IMG]
