good lens for indoor/moderate light, group photos. nikon d40
Discussion in 'Digital Discussion & Q&A' started by jzxxx, Nov 18, 2008.
  1. jzxxx
    jzxxx TPF Noob!
    Nov 18, 2008
    72
    california
    hey everyone, the holidays are coming up and i'd like to know what is a good lens to use with my nikon d40 to take group photos without using flash indoors with moderate lighting. i failed pretty bad with the kit 18mm-55mm lens. i'd like if that didn't happen again, haha.
    the lens' i already have are:
    kit 18mm-55mm lens
    50mm 1.8 lens
    thanks in advance!
  2. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,966
    14
    Durham, UK
    The 50mm would have been the best bet, flash with the other one. H
  3. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    Sigma makes a 30mm f/1.4. It's a bit pricey, but will meter and AF on your D40 and it's the ideal length as it's the approximate equivalent to the "standard" length on a 35mm frame. I've heard good things about it and seen some great images taken with it.
    The much cheaper (and perfectly competent) 50mm AF-D will do as well if you don't mind manually focusing, but you might find framing too tight for group shots.
  4. jzxxx
    jzxxx TPF Noob!
    Nov 18, 2008
    72
    california
    i already have the nifty fifty lens. i don't mind manually focusing either, how do you think the 28mm f/2.8 lens will do in the conditions i mentioned above?
  5. bigtwinky
    bigtwinky No longer a newbie, moving up!
    Oct 6, 2008
    4,820
    285
    Montreal
    With low lighting and not using a flash, you have to compensate with a wider aperture and a higher ISO.
    So your 50mm 1.8 would fair better than the 28mm 2.8 as it has a wider aperture for the lighting. Not sure about the 28mm vs 50mm for group shots. I would think the 28mm would be better for a larger group, but the 50mm can do a good job if the groups are smaller
  6. epp_b
    Aug 22, 2008
    2,135
    12
    I imagine pretty well. It's about half the length and one stop slower, so it should pretty much even out and have the potential to let in the same amount of light.
  7. jzxxx
    jzxxx TPF Noob!
    Nov 18, 2008
    72
    california
    cool, i thought so and thanks everyone for the input.
  8. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    Why are you avoiding using a flash? A good flash with some knowledge of how to use it (IE diffuse and bounce), will create better results then a fast lens.
best lens and setting for taking group photos
best lens for indoor group photo
best nikon lens for group photos
best nikon lens for group shots
best nikon lenses for group photos
how to take great group photos indoors
nikon lens for group picture taking
what is a good indoor nikon lens
what is the best lens to use on my nikon d40
what is the best nikon lense for taking photos indoors
