GoPro Chest Mount Question
Discussion in 'GoPro Cameras' started by WillygLounge, Mar 19, 2014.
  1. WillygLounge
    WillygLounge TPF Noob!
    Mar 14, 2014
    69
    8
    I own a GoPro chest mount that I use for my hiking trip. I always run into the problem that the video being too shaky. Though I do understand there is no way to record a whole video 100% shaky free with this mount. However, is there a way I can reduce it so when I use dehsaker to process my videos, they will appear better?
  2. ratssass
    ratssass TPF Supporters Supporting Member
    Nov 24, 2011
    1,503
    550
    Downtown Volney Center
    subscribed.......also interested
  3. astroNikon
    astroNikon 'ya all Bananas I tell 'ya Supporting Member
    Aug 15, 2013
    13,279
    3,230
    SE Michigan
  4. WillygLounge
    Mar 14, 2014
    69
    8
    Deshaker is a plugin for Virtualdub to stabilized video.
  5. TheNevadanStig
    TheNevadanStig No longer a newbie, moving up!
    Feb 18, 2014
    692
    596
    Reno, NV
    I don't see a major way to stabilize a chest-mounted gopro without greatly changing your gait, which isn't going to be comfortable during a hike. You could try mounting it to your pack or something and it might improve a bit.
    • Like Like x 1
  6. WillygLounge
    Mar 14, 2014
    69
    8
    Thanks for your suggestion. After so much frustration, I decided to use my Canon PowerShot SX50 HS to record most of the hike. When I'm setting up equipment, driving, climbing, walking in a stream and other activities, I use my GoPro.
    It seems the suctions cup does a good job while driving. It rare the video is shaky and when it is, Deshaker will stabilized the video for me.
  7. TheNevadanStig
    Feb 18, 2014
    692
    596
    Reno, NV
    Well driving, the vehicles suspension is greatly smoothing out the shake as well. Walking is a whole different thing, as you're going to get a pretty good jolt with every step. A headlamp-type mount might reduce the shake a little as well, as the higher up you go on your body the movement from steps would be a little less noticeable.
    • Like Like x 1
  8. Designer
    Designer Been spending a lot of time on here!
    Apr 13, 2012
    16,229
    4,072
    Iowa
  9. WillygLounge
    Mar 14, 2014
    69
    8
    Buddy you just broke my pocket book lol :)
  10. Exco
    Exco TPF Noob!
    Jan 10, 2013
    40
    VA
    I own a chest and head mount and found that the head mount is a lot less shaky.
  11. WillygLounge
    Mar 14, 2014
    69
    8
    Thanks I will invest in one.
  12. DBA
    DBA No longer a newbie, moving up!
    May 10, 2012
    190
    43
    United States
    Which GoPro do you have? If you have the GoPro Hero 3 Black you could record in 2.7K. This will give you a lot more room to work with to reduce the shakiness, while still having your output be a native 1080p.
    Like Exco said, the helmet mount/view tends to be a lot smoother.
