Grainy shots on snow?
Discussion in 'Film Discussion and Q & A' started by et5057, Mar 12, 2008.
  1. et5057
    et5057 TPF Noob!
    Mar 12, 2008
    5
    Hey guys,
    So Ive been shooting with an old Pentax K1000 and most often Ilford HP-5 film. I shoot pictures of skiers mostly in the air, above the horizon line, against the blue sky with the white of the snow beneath them. When I print, the pictures, although properly focused, come out reaaaally grainy. They look as if they hadn't been focused, but I am POSITIVE that they are focused correctly.
    My light meter reads true, right in the middle, when I am taking the shot, and I, for the most part, shoot with a shutter speed of 1000 and an aperture setting on the low end. What could it be?
    thanks
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    it is not uncommon for middle values in a black and white image to accent the grain pattern.
    that an a lack of detail will always show more grain than images that have serious amount of detail.
    As far as you light meter knows, the blue sky and white snow are middle values.
  3. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Your shots are most likely underexposed, which will, when corrected at the lab, will cause grain.
    Your camera's meter always assumes that the scene is mid toned...18% grey. So when it's not (a lot of white snow)...accurate exposure isn't right in the middle.
    When your scene is brighter than 18% grey, you will probably need to add exposure from the meter reading. When it's darker than 18% grey, you will probably need to subtract exposure from the meter reading.
  4. petey
    petey TPF Noob!
    Oct 14, 2007
    311
    brother sky itz
  5. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,965
    14
    Durham, UK
    Overexpose by 2 - 3 stops, sometimes 4 on the brightest days. H
  6. et5057
    et5057 TPF Noob!
    Mar 12, 2008
    5
    ah yes thank you. It makes sense-the light meter is trying to balance between the darkness of the blue and the trees etc. and the white so then it is underexposed and when I corrected them in the dark room they became grainy. or something like that.. thanks guys
photo grainy snow
