Grand Cayman HDR After The Storm C&C
Discussion in 'HDR Discussions' started by Provo, May 23, 2010.
  1. Provo
    Provo TPF Noob!
    Oct 27, 2009
    934
    20
    Ex Member
    I took this image after a heavy rain storm overlooking the bay.
    [​IMG]
    ---Photomatix Edit Settings---
    [​IMG]
  2. Provo
    Provo TPF Noob!
    Oct 27, 2009
    934
    20
    Ex Member
    Bynx I am awaiting to hear from you :lol:
  3. Josh220
    Josh220 No longer a newbie, moving up!
    May 23, 2009
    1,730
    83
    California
    I'd try backing off the Strength and maybe also a little of the Luminosity/Micro contrast. You don't want it to look too fake. Also, under "Smoothing" check the Light Mode box and adjust via the options that appear. Max usually works best, but try each one.
    It looks like it had some trouble with the water. Was this from one image or did you take 3 separate? You may need to adjust the import settings so it detects moving objects like water.
  4. Provo
    Provo TPF Noob!
    Oct 27, 2009
    934
    20
    Ex Member
    The minute you check on smoothing options light mode enabled and go below mid that's when the halo's start. So now I don't use light enable mode I just use the smoothing slider 3 images 2Ev.
    Here some of the other HDR images I have done so you can see.
    [​IMG][​IMG][​IMG]
    [​IMG][​IMG][​IMG]
  5. Bynx
    Bynx No longer a newbie, moving up!
    Feb 8, 2008
    2,804
    366
    Just outside Toronto Canada
    I like your results Provo. As mentioned, its too bad about the water. But maybe we could see the files your used. From what I see here I think my favorite is your sunset. As for the water in your first shot perhaps you could pick up some details by cloning from the middle shot the waves with the cloning tool set to darken and about 80%. That should fill in that blank area.
