Group Portraits + Lighting + Glasses Glare
Discussion in 'Beyond the Basics' started by prixdc, Mar 2, 2009.
  1. prixdc
    prixdc TPF Noob!
    Mar 2, 2009
    New to the forums, first post!
    Here's the deal:
    Once a week I take between 5-7 group portraits with 10-20 people in each. I am using three lights w/umbrellas. Left and right are high, bounced off of the white ceiling, and one is centered, low, about 12 feet in front of the people.
    My problem is with glasses glare. I have usually 2-5 people in each group wearing glasses, and while some glare is easily fixed by cloning, patching, healing, etc in Photoshop, some is too bad to fix without making it worse.
    This wouldn't be a problem if I had ample time to work with each group, specifically the people wearing glasses, but I have to get the groups in and out in less than 10 minutes and come out with a decent photo. I don't have time to rearrange lights for each group, or ask people to remove lenses. I don't like people taking off their glasses either--they ususally squint and look unnatural.
    I've resorted to taking one exposure with everyone's glasses off, then the rest with them on, and playing cut and paste with the eyes. This works, but can be tedious if there are a lot of glasses.
    The glare usually comes from the low, front light, but changing angle doesn't work, and lights everyone unevenly. In general I am happy with the exposures, its just those dang glasses!
    Thoughts about this?
  2. Seefutlung
    Seefutlung TPF Noob!
    Apr 13, 2007
    1,558
    62
    SoCal
    In the original Superman series (B&W), the director had the same problem so he removed the lenses from Clark Kent's glasses.
    Gary
  3. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Welcome to the forum.
    A trick that I've used a few times, is just to have the person/people with glasses, angle their glasses downward slightly by raising the arms up higher on their head. This doesn't work for everyone and it can look unnatural...but in a group setting it might go unnoticed and solve the glare problem.
  4. prixdc
    prixdc TPF Noob!
    Mar 2, 2009
    Thanks, Mike. I like the looks of this place, I think I might stick around...
    I have tried this, and you're right, it does work sometimes, but I've had it actually make it worse before, which stinks.
    Also some people don't get the concept and I have to struggle with them to not bring their glasses down the bridge of their nose, just pivot, then they get frustrated with me and just take them off :(
    Would a pol. filter do anything to help?
  5. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    It might help but it might not...I can't say for sure.
    In a shot of 10-20 people, I might be temped to just leave the glasses as it or have them take them off and live with the squinting. I'm guessing it's more a record of a group of people as opposed to a formal portrait sitting.
  6. dEARlEADER
    dEARlEADER TPF Noob!
    Apr 9, 2008
    1,312
    Canada
    can you add another fill light and position them camera right and left instead of just shooting one up the center?
  7. Mike_E
    Jan 26, 2007
    5,327
    266
    Try lowering the two on the outside and raising the light in the middle. Light acts just like a ball on a billiards table- it bounces just like one anyway. (OK, a tiny little ball that can go any which way according to how ruff the bumper is but taken as a whole averages out) The specular highlights you're getting from the glasses are coming from the middle strobe so by using the ones on the sides as mains the reflected light is shunted to the walls and away from your camera.
  8. Prophotoworkshop
    Prophotoworkshop TPF Noob!
    Mar 1, 2009
    10
    NYC
    Forget the middle light.........one light on either side, point them inward.
    or
    Bring a bunch of frames (glass frames)with you to the shoot ( with out lenses )
    let them pick a pair that suits them your off and running no times wasted.
    or
    Shake it off, that's the nature of the beast But I think your best bet is figuring out the right lighting scenario.
    Photoworkshop
  9. NateOntario
    NateOntario TPF Noob!
    Oct 3, 2007
    53
    Southern Ontario, Canada
  10. Kcc
    Kcc TPF Noob!
    Dec 27, 2008
    51
    Toronto, ON. Canada
    I am still new to camera, but hope this help...
    Lenses for glasses have different "base curves", some could be flat and some could be round on the front of the glasses. Different angels for the side flash might not solve the problem if there is different lens curves for the people you are shooting.
    As post #7 (Mike E) had mention, lowering the flash on the side might help alittle.
    To support my "base curves" theory, I have been work in the optical industry for 10+ years. Hope it helps.
    Kcc
  11. C.Lloyd
    C.Lloyd TPF Noob!
    Oct 22, 2007
    299
    Holly, Mi
    My first thought was to reverse the lighting setup... bounce the center light off the ceiling and lower the two side lights. You'd have to adjust the power levels accordingly, but I don't think it'd be too tough.
lighting a group portrait
