Happy WWPPD
Discussion in 'Alternative Techniques & Photo Gallery' started by smithdan, Apr 24, 2016.
  1. smithdan
    smithdan No longer a newbie, moving up!
    Sep 1, 2012
    534
    476
    Southwest Alberta Canada.
    Not a nice day around here so had to teach a new dog old tricks and crank a homemade pinhole bodycap onto the front of my K S2. This years effort..
    • Like Like x 4
  2. Watchful
    Watchful No longer a newbie, moving up!
    Mar 16, 2016
    1,130
    252
    Arizona
    Did you make the hole in foil?
  3. limr
    limr Moderator Staff Member Supporting Member
    Jun 9, 2013
    16,891
    9,047
    I've got my ONDU loaded and took a few frames. It'll be a while before I finish the roll :)
    • Like Like x 2
  4. smithdan
    Sep 1, 2012
    534
    476
    Holes made in foil are usually too large and irregular shaped making an image that is too fuzzy. Made mine in a flattened piece of aluminium beer can using a small sewing needle held in a pencil eraser for a drill, like this:
  5. Watchful
    Mar 16, 2016
    1,130
    252
    Arizona
    We used foil when we made ours, but we also made the rest of the camera out of a shoe box so we could set the film plane in the exact spot for prime focus, I guess it's different when you use a ready made box.
  6. Tim Tucker
    Tim Tucker No longer a newbie, moving up!
    Mar 23, 2015
    660
    577
    Err, there is no focus on a pinhole camera. Distance between film and lens = focal length. ;)
  7. Watchful
    Mar 16, 2016
    1,130
    252
    Arizona
    The focus is the spot where the image intersects the film plane.
    Increasing the distance from the opening enlarges the image and it becomes less defined.
    There is a spot where the image will be its sharpest and fill the plane.
  8. vintagesnaps
    vintagesnaps Been spending a lot of time on here!
    Jan 13, 2013
    6,537
    1,901
    US
    Nice photo.
    I thought about getting out one of my pinhole cameras... and that was as far as I got! But the day if nothing else gets me thinking about pinholing. Takes me awhile to finish the roll too, I won't be surprised if there's still film in one of them from last year.
    • Like Like x 1
  9. smithdan
    Sep 1, 2012
    534
    476
    Have a collection of bits and a uniquely shaped tea tin and some ideas of what to do with them - maybe next year. Got lazy and went digital this time around.
    Somehow not the same though.
    • Agree Agree x 1
  10. limr
    Jun 9, 2013
    16,891
    9,047
    Well, I loaded the pinhole yesterday and took a test shot. The other shot ended up not happening, though I might try it again tonight (I'm thinking a several-hour long still life with just one lamp).
    I have the Ondu with me today and am experimenting with a few things. I'm going to count anything on this roll as counting for WWPPW (World Wide Pinhole Photography Week ;) )
    • Like Like x 1
  11. smithdan
    Sep 1, 2012
    534
    476
    If it's any help exposure wise, the bowl of fake hydrangeas was lit with two 60w (equivalent) LED bulbs, fill at about 3 1/2 ft., key at about 2 ft., camera ISO at 400, time 24 sec. This is of course at approximately 35 mm film (sensor) distance from the hole and my homemade pinhole is probably a few " seconds" larger than the better made one in the Ondu. You do the math for your application!
    ..and I'll never rat on the "week" thing..
    • Informative Informative x 1
  12. timor
    timor Been spending a lot of time on here!
    Feb 28, 2011
    5,862
    875
    Toronto ON
    Tim is right. Image is "intersecting" film plane always but the "best" quality is, when the circles of confusion are smallest which, incidently, is at the focal lenght. As it relatively easy to measure the focal distance the problem is to make the pinhole of the right size for it as to large or to small will render the picture fuzzier, than possible. There is one method to check the pinhole size and perfection using the enlarger.
