GlennT
- Joined
- Dec 10, 2013
- Messages
- 52
- Reaction score
- 10
- Location
- Michigan
- Can others edit my Photos
- Photos OK to edit
Somewhat of a long brain dump, so my apologies up front.
I guess I could preface this with the fact that I had planned on getting a Canon 24-70mm f/2.8L (Mark I), but never had the funds. Now I do. Also, I have a Canon 70-200mm f/2.8L and I was planning on something like the 16-35mm to cover the wider range, with the 24-70 living on the camera at most times.
The Tamron 17-50mm f/2.8 has always been a decent lens (bought 2007), but I've been less happy with it since since I got a Canon 7D. Even with micro adjustments, it either slightly front focuses or back focuses, depending on which end I adjust for (i.e. doesn't focus linearly). It's really only a problem at f/2.8, but it's annoying to know the issue is there. More than anything, I'm sick of the AF hunting in low light.
I've shot with a friend's 24-70mm f/2.8L several times, and really like that the filter threading is the same 77mm as my 70-200mm. I'd have to buy one used though.
The 24-70mm f/2.8L Mark II is doable, but I'm purely a hobbyist; $2000 is tougher to justify as a result. I fear this is the lens I want, even if it requires larger filters.
The Tamron 24-70mm f/2.8 VC is enticing, particularly since it appears that the VC performs well, and it is a fairly sharp lens (if you get a good copy.) I rarely shoot video, but IS/VC/OS would be nice. That said, I originally bought a Tamron 70-200mm f/2.8 and ended up with the Canon 70-200mm f/2.8L simply because it felt better and I was happier with the AF, so I have mixed feelings about Tamron in general.
And then I'm also considering the Canon 17-55mm f/2.8. I haven't handled one in person. I know it's a well regarded lens, and I could cover a pretty good range with just two lenses, while saving a considerable amount of money. I know it's probably the lens I should want. I don't know if I'm just skeptical, or if I'm preferring the 24-70 range, or if I just fear buyer's remorse; a feeling that I settled for the cheaper option. It does take 77mm filters, so big bonus there. While I know it's an upgrade from the Tamron, just how much of an upgrade, I don't know.
I know 24-70 would suite me just fine. When using the 17-50, I tend to find myself wanting more on the long end than the wide end. I do shoot landscapes occasionally though; more rarely do I shoot large group photos, but it does happen. I can certainly get by with the Tamron for those shots, since those shots generally need more DoF and keep it out of the "dangerous" f/2.8 territory.
I feel like I'm rationalizing myself in circles. Any thoughts?
Regards,
Glenn
Regards,
Glenn
