HDR and noise in shadows...
Discussion in 'Beyond the Basics' started by fiveoboy01, Sep 23, 2009.
  1. fiveoboy01
    fiveoboy01 TPF Noob!
    Dec 28, 2008
    684
    Waunakee, WI
    This is a 5(or 7, can't remember) exposure, .7EV spacing done in Photomatix.
    [​IMG]
    I had a print delivered from Smugmug and the underside of the bridge is just a pile of noise. It's the worst closer to the rocks where there was less light. From a distance you can't see it but I eyeball my prints and this looks horrible to me.
    Is there a technique specific to HDR photography that helps reduce noise in shadows? Would it be better to take fewer exposures, such as 3 with 1EV spacing? ISO was low, 200 or 400 so I am not sure if that caused this or not.
  2. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    With HDR, 200 or 400 isn't enough. You need to get right down to the absolute low end of your camera, wherever there is the absolute least amount of noise. You then need to use good noise reduction techniques to attempt to eliminate as much of it as you can (which further increases the need for perfect technique and solid gear when creating HDRs, as you also need to capture the sharpest image you possibly can while you're doing this...what fun!).
    The more exposures you use for the HDR, the more noise will crop-up and be magnified. So you also need to be sure that you're taking an appropriate number of exposures for the scene (that is, meter the darkest shadow, then the brightest highlight, and shoot 1 stop increments in between).
  3. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Errrm hangon a minute. Here we have a picture that looks noise free and you say that when you get the picture back it has noise?
    Is the tone of the print the same as the picture? Is the sharpness the same? My guess is smugmug are screwing with the settings making your picture "nicer" and during the process it's bringing out some noise. I see no reason why printing that pristine looking picture should cause noise.
  4. DeadEye
    DeadEye TPF Supporters Supporting Member
    May 16, 2007
    960
    11
    Yea That is what I said.
    So many online print houses assume that its a point and shoot snap without PP. They "enhance" by default if you dont check the box that says do not do so. Pro print shops assume the file is ready to print as is.
  5. McNugget801
    McNugget801 TPF Noob!
    Jul 13, 2009
    388
    43
    I never shoot HDR on anything higher the ISO100.
    On the darker noisy frames I will do a bit of noise reduction before processing .... also blowing out an area (usually the sky) will cause some artifacts in these areas.
  6. fiveoboy01
    Dec 28, 2008
    684
    Waunakee, WI
    The print looks the same, tone-wise.
    If I view the original on Smugmug, I can see the same noise underneath the bridge that is on the print. Er, maybe it's artifacts and not noise, not sure on the diff there. I can post up the original if anyone wants.
