HDR help
Discussion in 'Digital Discussion & Q&A' started by neogfx, Mar 1, 2008.
  1. neogfx
    neogfx TPF Noob!
    Nov 21, 2006
    387
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    what software are you using to merge these together?
  3. kidchill
    kidchill TPF Noob!
    Jan 27, 2008
    249
    Brooksville, FL
    I would suggest using Photomatix Pro. I prefer it to PS3. It comes with a step by step tutorial on the way to combine them. You may want to use less than 8 exposures, depending on the EV steps involved.
  4. AspiringArchitect
    AspiringArchitect TPF Noob!
    Feb 4, 2008
    73
    8 exposures?!?! Awesome!
    When I run 3 raw images together photomatix takes about a minute and thats with 2g ram and a fast processor.
    What are your comp. specs?
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    AspiringArchitect try more exposures. You'll see it doesn't take much extra ram it just takes longer to process the photos. The final image is the same 32bits.
    I don't know much about HDR but 8 exposures are too many.
  6. neogfx
    neogfx TPF Noob!
    Nov 21, 2006
    387
    I was told the more the better, the computer will just choose not to use the data it doesn't need so apparently you don't lose anything by including extra, whereas it could kill your image if you haven't got the data there that you need.
    I started using CS2 and could not get my adjustments right, the final image never resembled what I saw.
    I have downloaded a copy of Photomatix Pro, but I get a similar problem. When I come to edit the tones I can't get it to look like the scene I saw and it looks kind of surreal.
  7. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    HDR will make thing look surreal unless you tone down the adjustment, Photomatix imo is the best progam, CS2 has a terrible HDR function. When you are adjusting the image in Photomatix use a value of 50 to 70 for the overall stregth of the HDR image (I forget the name of the slider but its the top one, I havent used HDR in a while) This will lessen the surreal look, also as for the other adjustments do not push them to their limits, subtle adjustments are needed to create real looking images.
  8. neogfx
    neogfx TPF Noob!
    Nov 21, 2006
    387
    Thanks D-50, I'll give that a go.
  9. KenCo
    KenCo TPF Noob!
    Apr 25, 2006
    518
    North East UK
