HDR/Photomatix Problems
Discussion in 'HDR Discussions' started by BallazDream32, Dec 22, 2009.
  1. BallazDream32
    BallazDream32 TPF Noob!
    Dec 11, 2009
    Los Angeles
    Okay, so when I import the 3 images into photomatix, I get this strange thing where the pictures seem purple/pinkish when they're merged. Not only that, but I get this pinkish line along the right side of the pictures as well. I'm new to photomatix, but I know that my pictures shouldn't really look like this. What's going on?
    [​IMG]
  2. Provo
    Provo TPF Noob!
    Oct 27, 2009
    934
    20
    Ex Member
    [​IMG]
    Alternative If you have photoshop you can merge to hdr then export it as a single hq tiff file into photomatix and your images might be better aligned I sometimes go back and forth on the method but often this method helps alot with moving sections of your hdr such as people or cars the results are much better aligned in ps hope this helps you out.
  3. Bynx
    Bynx No longer a newbie, moving up!
    Feb 8, 2008
    2,804
    366
    Just outside Toronto Canada
    Was your pic hand held? Ive never had this happen to any of my HDRs. Unless you know there was movement in your pic uncheck ALIGN SOURCE IMAGES and ATTEMPT TO REDUCE GHOSTING ARTIFACTS. I keep Reduce Chromatic Aberations and Reduce Noise clicked. Is that the way the pic looks color wise after the first step (Generate HDR) or after the second step (Tone Mapping).
photomatix turns photos magenta
