Help! Camera Dead (I think)
Discussion in 'Photography Beginners' Forum' started by Buszaj, Feb 9, 2008.
  1. Buszaj
    Buszaj TPF Noob!
    May 23, 2007
    521
    Toronto
    Hey everyone,
    My camera (Panasonic Lumix DMC-FZ3 if it helps, a P&S), is acting up. When I turn it on, the screen is simply black; the settings are all present on the screen (ISO, picture type, exposure, etc.) but the rest is just black. If I do take a picture, it just comes out black. I have tried switching memory cards, removing the batter, every setting, put everything to default, everything. Can anybody help?
    Here's the actual screen:
    [​IMG]
    Thanks a lot.
  2. R0TT3NBURIT0
    R0TT3NBURIT0 TPF Noob!
    Feb 5, 2008
    59
    FL
    did you leave you lens cap on?
  3. Buszaj
    Buszaj TPF Noob!
    May 23, 2007
    521
    Toronto
    lol, no.
  4. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    hmm.. no signal from the sensor?
    looks bad then.
    maybe you can "reset" the camera somehow .. maybe this is a software issue.
    but i would guess it is something worse and service is needed.
  5. Buszaj
    Buszaj TPF Noob!
    May 23, 2007
    521
    Toronto
    Ya I was thinking that somehow the "brains" of the camera just can't receive the image. It's been serviced once before and I'm not sure if it will be worth doing again, we'll see. Maybe I'll finally buy/get the SLR I'm hoping for....
  6. passerby
    passerby TPF Noob!
    Jan 21, 2008
    591
    If it is still under warranty it is advisable for you to just return it. If they can't fix it than you may recieve the replacement for it or a refund. Just like my nokia n95 that I bought 3 days ago. It playing up from day one until this afternoon. It froze when I activated the camera. The switch off button too ineffective. I had to remove the battery to reset it every time it froze. Well, I just got home from the shop with the new replacement for it. This one works fine.
    They don't actually fix the faulty mechines anymore these days, they just replace it. Your lumix I think is very current camera, I assume it is still under warranty.
  7. Happy Hour
    Happy Hour TPF Noob!
    Dec 5, 2007
    453
    Chicago IL
    does your camera have a reset on it? have you tried taking the batteries out for a few mins and then repowering up? sometimes the just freeze up. I've had this happen a few times on different cameras reseting them usually does the trick. (at least hope!)
  8. Buszaj
    Buszaj TPF Noob!
    May 23, 2007
    521
    Toronto
    This camera is actually 5 years old, its been through a lot, like falling in water from a canoe, but it has worked for a while, up until a few days a go. I'm gonna take it to the service place where I serviced it before and see, if it's not worth it, we're just going to buy a new camera, (yay!). Thanks for the replies.
  9. RKW3
    RKW3 TPF Noob!
    Apr 30, 2007
    1,716
    So Cal
    LOL sorry that sounds pretty funny.
    Yeah go have it checked, if it's done for you should probably look at the DSLRs.
  10. SBlanca
    SBlanca TPF Noob!
    Dec 28, 2007
    405
    Gibraltar
    im guessing the water might have something ot do with this...i remember this friend of mine threw a water balloon out my bedroom window but missed slightly and it bounced back in and blew up over my computer monitor...it worked fne for a long while but then got messed up for no reason
  11. Noob7_0
    Noob7_0 TPF Noob!
    Dec 23, 2007
    16
    Ontario, Canada
    Same thing just happened to my P&S...coincidence?
  12. vituccin
    vituccin TPF Noob!
    Jul 7, 2007
    35
    My old p&s does this too. Believe it or not I would shake it a little and it would work again. This isn't necessarily solving the problem, but try that out and see what happens.
