Help choosing camera. 1000$ budget
upper
what's the best that i can get for 1000$ or less?
i'm looking for dslr camera
lens that is sharp/can do macro shot/ long range shot.
and any other accessory that i need.
With $1000 or less budget, I would say go out and try few of the low end DSLR cameras and see which one feel the best in your hand.
I will say spend less on the Camera body and use the rest of the budget for the lens or flash
For a bit more ($1170 or something like that) you could get a Canon 40D with a 28-135mm, which will do decent macro and long range.
I would definitely suggest one of the lower end Nikons and then use the rest on a quality lens. I have found the lens makes far more of a difference then the camera body.
I second Dao's remarks, spend less on the body and more on the glass.
What would recommend? For $1000 you're not going to get L glass, or any fancy Nikon glass AND a body. The 40D is hard to beat right now ($200 rebate).
Ok, there's an exception to that. If you get an XT and a 17-40mm f/4L or 70-200mm f/4L. The 17-40mm doesn't meet any of the conditions he set, so that's out. The 70-200mm f/4L would be a good option, but you're fairly limited in what you can shoot with that. If you KNOW you're never going to need anything wider than 70mm (which would probably don't know, if this is your first dSLR) then go with this. Otherwise, 40D it is.
I did not realize the 70-200mm L lens existed for such a price! Thanks for mentioning that I may need to start saving for it.
Yes, the 70-200mm F4L is less than $600 in most places. It is currently US$560 shipped from Adorama.
I recently was able to try the IS F2.8 version in my friend's 1Ds and what a big different from the much cheaper Canon lenses that I have. (BIG different in Camera as well)
The L lenses that he had are a lot quieter and smoother, not to mention the image quality. And after playing with it for few minutes, I can see why they cost more. But holding the 1Ds with the L lens attached for awhile, I can see why my friend need a monopod.
XTi Rebel Body
50mm f/1.8(will i need a wider lens? how big is 50mm?) i heard it was good
sigma AF 70-300mm APO macro lens
and
A 20$ tripod
I have the XTi and I use the 50mm as a walk round lens. I wish it was a little wider, with the 'magnification' (really just cropping) of the xti, the 50mm becomes larger actually.
But, the 50mm is very suitable if you do not desire a wide lens. I currently use it for everything right now. You really cant beat it for the price.
About the tripod, I also use a cheap one. It was only $30 shipped from a company called amvona.
They sell a lot on ebay.
http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=amvona
It is very nice for the price!! And they have really good customer service.
XTi Rebel Body
and
A 20$ tripod
The Sigma AF 70-300mm APO macro lens is okay lens. Nothing really stand out. The Canon 55-250mm EF-S IS lens maybe better (if the extra range is not that critical) But it is $280 at Adorama
For me, the 50mm f/1.8 is pretty sharp for the price. But personally, I think it is not wide enough. But I still like it a lot.
Also, Tamron AF 17-35mm f/2.8-4 Di LD seems to be pretty good for the price. Adorama sell it for $289 after rebate
But $280 + $290 is equal to $570 already. That leave you $430 for the camera.
For me personally, I will get the camera body and the Tamron AF 17-35mm f/2.8-4 Di LD $290 or Tamron SP AF 17 - 50mm f/2.8 XR DI-II LD $420 and save more for a good telephoto zoom such as the Canon 70-200mm F4 L $600 and add a 105mm Sigma prime later. But since the 50mm f1.8 is so cheap, so I need to get that as well.:lol:
i think that's more than i could afford. and i wanted the telephoto and the macro. dont know what's so bad about it.
if you really want zoom, the Olympus bodies offer a 2x crop... meaning every lens is really doubled... good and bad come with that, of course.
the e510s are going dirt cheap because they are being replaced by e520s
I'd fully agree with Rogan's choice. The 18-55 kit lens is surprisingly sharp and generally well-built, plus it doubles as a great close-up lens, while the 55-200 is very neat for sports & general wildlife shots (small birds can be a REAL pain with any lens), and the Vibration Reduction is very handy in some situations.
Also bear in mind that you should never stretch your budget for just the camera & a lens, as that is never just what you need. You'll have to get a memory card if you haven't got one already, a camera bag, possibly a tripod, the list goes on...
