Help!! I want to clean my sensor unit but I don't know where to begin.
Discussion in 'Beyond the Basics' started by Tyler2026, Nov 22, 2007.
  1. Tyler2026
    Tyler2026 TPF Noob!
    Apr 13, 2007
    27
    I want to clean the sensor unit on my canon XTi but I am not sure where to begin. Does anybody have any tips or know any websites that may help me out? Thanks a lot.
  2. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    is it really bad? If it isn't leave it alone...
    If it is...
    Make sure you read the manual...it mentions cleaning.
  3. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
  4. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Try a search of the forums...plenty of good info already posted.
    First of all, your camera has an anti-dust feature, which should mean that you have to do less cleaning than with an older DSLR.
    You can do a quick & easy cleaning with a rocket style blower bulb...but if the dust is persistent, then you may need to do a wet cleaning with swabs and cleaning solution.
  5. Tyler2026
    Tyler2026 TPF Noob!
    Apr 13, 2007
    27
    my camera is pretty much beyond the self cleaning feature and probably needs a wet clean
  6. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    I did a search on YOUTUBE... found at least 80 videos related to that.
    As for needing a drastic cleaning... if it is that bad, send it in or get a professional to do it. The last thing you want to do is damage your sensor. The cost to fix that could exceed the value of the camera.
    This is why people always change lenses in a place that has as little dust as possible, and use proper technique. Also a Giotto rocket blaster goes a long way in terms of preventive maintenance.
  7. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    The sensor is behind a protective layer of (glass or something similar)...and it would probably take quite a bit of force to actually damage it. If anything, I would be more worried about damaging the shutter or the mirror...but that wouldn't be easy because they are kept out of the way while in cleaning mode.
    Unless someone is an absolute klutz...I wouldn't bother to send it in just for a cleaning.
  8. RacePhoto
    RacePhoto TPF Noob!
    Dec 29, 2006
    562
    5
    Wisconsin
    I hate it when people answer questions, like I'm going to. But in this case... :lol:
    Did you consider trying a search here? This question comes up about once every two weeks and gets the same set of answers. (oh by the way, mine is the Copperhill site and system, I use it, it works, it's not expensive.)
    Then maybe you can try this really k00l site http://www.google.com and search for "sensor cleaning tutorial", gee look, first one is Copperhill, followed by Luminous Landscape!
    http://www.google.com/search?hl=en&q=sensor cleaning tutorial&btnG=Google Search
  9. Tayfun
    Tayfun TPF Noob!
    Nov 19, 2007
    139
    Istanbul/Turkiye
    http://ru.youtube.com/watch?v=M***wI_afY0
    This is a link from youtube which shows how to clean a sensor. If you write "cleaning sensor" and make a search you'll find lots of video tutorials about it like the one above. Watch the videos and select the one which you can dare to do. Actually I agree with Johnboy about it is not so dangerous if you care enough, but I would first try with an air pump blow on it. If not enough than choose one way to clean. Hope you to be succesful on that
