JonMikal said:i may slip out today and buy a cpu. it will only be used for image editing and internet. what is the minimum i could get by with: p4?, speed, ram, etc.
thanks in advance for your ideas :thumbup:
Xmetal said:Depends which chip you're refering to...
Athlon = Pentium
Duron = Celeron
or something along those lines.
JonMikal said:oh, i almost forgot and i know it's a debatable question; is there any particular brand to stay away from.
robhesketh said:If PS is your primary performance application you may want to have a look at:
http://www.adobe.com/support/techdocs/318243.html
Rob
JonMikal said:great info.
btw, can you mix ddr and ddr2? say you had a 512 ddr chip and a 512 ddr2 chip, is that better than (2) 512 ddr chips?
Verbal said:It's pretty much a waste... I believe using two sticks like that will simply downclock your DDR2 to the speed of normal DDR.
