HELP! My Memory Card has an Error!
Discussion in 'Beyond the Basics' started by AprilRamone, Mar 5, 2006.
  1. AprilRamone
    AprilRamone TPF Noob!
    Nov 3, 2005
    1,280
    Denver
    I meant to post this here but accidentally posted it in the equipment advice and reviews section (Mods, do you want to take that other one down?)
    Ok, so I just got into doing digital photography and haven't had a problem until now! I have a 4 GB Hitachi Microdrive card for my Canon 20D. I was at a shoot the other day when I tried to take a look at the pictures to show my client and all of a sudden there was an error message. And the last few pictures I had taken were missing. However, everything else way before the error message was still there when I got home to put it on my computer (THANK GOD!) I ended up just switching to my back up memory card. Can anyone please help me figure out what to do about this? I spent a good amount of money on this card and I don't know if I could find the receipt (or if they would even take it back at this point since it's been a few months). I have a photo shoot today and it looks like I have to use the back up card and that freaks me out!
  2. cpeters
    cpeters TPF Noob!
    Feb 4, 2006
    23
    Kutztown PA
    What was the error code (did it post one)? The first thing I would do is reformat the card and go out and do a bunch of test shooting. If the error reoccurs then the microdrive itself is going bad (which is rare BTW) I would then ditch it and buy a new one. Just my 2 pence.
  3. AprilRamone
    Nov 3, 2005
    1,280
    Denver
    Ok, so I just formatted both of my cards. They seem to be doingn ok now. I guess we'll see for sure when I have the shoot today. Is there anything else I should know?
  4. cpeters
    cpeters TPF Noob!
    Feb 4, 2006
    23
    Kutztown PA
    Keep an eye on it. If it is a media error, reformatting may/should have corrected it. Reformatting puts all the bad sectors into a "no use" area on the drive. If it is a progressive problem, then it will crop up again. Reformat the drive after EVERY use (yes EVERY- multiple underlines there) Take lots and lots of shots, literally put the card through a "stress test". If the card is bad then take it back to where you bought it. The microdrives have a one year warranty. If you paid by credit, then the purchase should be on record (also check your bank statements as backup). In the meantime use it, and keep a close eye on it. Wish I could be of more help!
  5. ajmall
    ajmall TPF Noob!
    Mar 24, 2004
    656
    Leicester, UK
    my friend had similar problems with his 300D a few months back because he rarely formated his cards and just deleted pics. i always format and have never had a problem.
  6. AprilRamone
    Nov 3, 2005
    1,280
    Denver
    I so am not computer/tech savvy. I had no idea you were supposed to format the card. I wonder why sales people don't mention that sort of thing when you tell them you are getting into digital photography for the 1st time?
    In any case, I have just been deleting images once I've put them on my pc. So, now I should delete them and then format it before every photo shoot I have?
  7. darich
    darich No longer a newbie, moving up!
    Jan 22, 2005
    1,230
    Near Lanark, Scotland
    If you do take it back then I'd recommend exchanging it for a CF card rather than a microdrive. With no moving parts the CF cards are more reliable and robust.
    I've had a couple of problems using Lexar cards and Lexar recalled some a while back. I've lost a bit of confidence in Lexar since then and try to use my SanDisk cards as much as possible. Never had any trouble with them.
  8. AprilRamone
    Nov 3, 2005
    1,280
    Denver
    Hmm...I have a Lexar 1GB CompactFlash as my back up card. What's the difference between the two? I thought they were the same thing just different brands and a different amount of storage on each one!
  9. neverhappen
    neverhappen TPF Noob!
    Jan 31, 2006
    10
    Brisbane, Australia
    I would suggest always formatting cards, and formatting in the camera not with the computer.
    Have to agree about the Sandisk cards too. Never a problem with these but have with some other cards.
    A little off track I prefer more smaller cards (1Gb or so) than single larger cards. Know it means the occasional swapping, but less risk if there is a card failure and there are also times when I dont want to immediately clear them from the card.
    neverhappen.com
  10. cpeters
    cpeters TPF Noob!
    Feb 4, 2006
    23
    Kutztown PA
    The sales people didn't mention prolly cause they weren't aware either. Most camera shops have maybe 2-3 savvy people and the rest are there for sales filler. Also many of them are there for the job, not the love of the medium.
    In short, yes. Format the card before every shoot.
  11. cpeters
    cpeters TPF Noob!
    Feb 4, 2006
    23
    Kutztown PA
    Nope. Compact flash, xd cards, smart media are all what is called static memory. They have no moving parts in them. The image is held as a static memory address, which enables it to be more stable and to hold more. Microdrives are just that, a mini hard drive with magneto-optic hardware and tiny disks that are written to. For the most part they are very stable, but occasionally do go bad.
  12. darich
    Jan 22, 2005
    1,230
    A CF card is physically smaller than a microdrive. You'll probably be able to use a CF card where you can use a microdrive but you won't be able to use a microdrive where a CF card is required because the microdrive is largere and won't fit where a CF card will.
    If you listen carefully to a microdrive you can hear it spinning. it uses more battery power, is slower and with moving mechanical parts is more sensitive to damage and impact. I found that my microdrive was sensitive to heat - after prolonged use it seemed more temperamental. I decided to change to CF cards before it became a liability and i lost photos on it.
    I'd always opt for CF card even if it was more expensive.
    Neverhappen has a good point of using smaller cards - don't put all your eggs in one basket - I have 4 1gb cards rather than 1 4gb card.
can memory cards go bad
do memory cards go bad
how do memory cards go bad?
how if my memory card fail
how to save spoil memory card
my memory card has an error
my memory has an error
what do i do when my media card contains an error?
when memory card goes bad
