Help needed with shiny objects.
Discussion in 'Photography Beginners' Forum' started by Agardner85, Oct 12, 2009.
  1. Agardner85
    Agardner85 TPF Noob!
    Oct 12, 2009
    Hello there. I am trying to take pictures on some clothing (Asian if that helps you picture it better) that are made out of some pretty shinny material. I have been trying different things and I can not seem to take good pictures of these articles of clothing.
    I have a Cannon powershot G10 with 2x 500watt lights and a 100 watt light with a home made 15x15 cube light box
    What I have tried so far:
    Natural lighting out side
    Natural lighting in the room
    Light boxes on the lighting only
    Uncovered lighting inside the light box
    Placing the article on the floor and flooding it with light from above.
    My problem is that the article of clothing has a very vibrate color to it and the lights will wash out certain parts of it making it look completely white from the shiny material it is made out of
    Can any one help me with some tips or a web site that might have some steps that I have over looked or not thought of?
    Thank you in advance for your help
  2. syphlix
    syphlix TPF Noob!
    Jul 23, 2009
    687
    NYC
    how about shooting it in open shade outdoors?
  3. Agardner85
    Oct 12, 2009
    Tried that as well, still had the same problem but with less severity.
    Also I need to be able to have a consistent set so that I can get lots of pictures taken
  4. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Do you have a sample such as the photo you took with the subject to show us what the problem is?
  5. Overread
    May 1, 2008
    24,079
    4,175
    UK - England
    If its reflection problems then the first thing I would try is a polarizer filter on the camera. That would cut down on the reflections and when rotated to the right position (experiment) you might find it helps you retain the colours you need
  6. Agardner85
    Oct 12, 2009
  7. Plato
    Plato TPF Noob!
    Jul 11, 2009
    1,058
    United States of America
    Overread's suggestion is the best. I can't imagine that you can attach a polarizer to a Powershot but you can easily hold it in front of the lens, It will be a minor difficulty rotating it to find the best position but, when you do, make a note of the position of the mark on the filter.
  8. Lyncca
    Lyncca TPF Noob!
    Jan 7, 2008
    1,881
    5
    Fort Worth, TX
    I am by no means a product shooting expert, but I would think you would want a little reflection like your sample to show the texture of the fabric? It looks pretty good to me....
  9. Plato
    Plato TPF Noob!
    Jul 11, 2009
    1,058
    If Lyncca is correct (and she may well be), you can use a polarizer to control the amount of reflection.
  10. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    Another here saying try polarization. Start out on the light side then progress it till you get what you want.
  11. Bitter Jeweler
    Bitter Jeweler Been spending a lot of time on here!
    Apr 27, 2009
    12,984
    4,976
    Cleveland, Ohio
    I'd like to see the results of using a polarizer for this.
    My bet is it won't do anything because fabric distributes light differently than glass or water. Just like a CP won't do anything for reflections in metal. Just my logical guess.
    I don't understand why you (OP) don't want to show that the product has sheen to it.
  12. chip
    chip TPF Noob!
    Oct 5, 2009
    377
    Cypress, CA
    Try using a circular polarizer. I think it will fix your problem. I have had similar problems before and the circular polarizer really fixed the problem completely. You should mount your camera on a tripod as the filter will reduce the amount of light entering you camera.
