Help on lenses
Discussion in 'Nikon Lenses' started by lunars, Dec 3, 2017.
  1. lunars
    lunars TPF Noob!
    Dec 3, 2017
    5
    Hello, I'm Luana and I'm not a professional, so I'm sorry if any of this sounds dumb.
    So I won a Nikon D3100 as a gift and two years later my camera fell into the pool. I know. I cried for a week straight. But since it was in the bag it somehow survived. The only damage was in the lens, my 18-55mm was blurry and it didn't dry out like everything else. So after testing I saw that it would work if I brought a new lens. I need your help to wich of these lenses should I buy that would work with my camera.
    AF-S DX NIKKOR
    18-55mm f/3.5-5.6G VR II or AF-S DX NIKKOR
    55-200mm f/4-5.6G ED VR II or the one my camera came with
    AF-P DX NIKKOR
    18-55mm f/3.5-5.6G VR? They are in order from cheaper to more expensive.
    Again I'M SORRY if this sounds really stupid but I'm not a professional, I tried but I don't understand the difference betweet a VR I to a VR II and stuff like that, I just like taking amateur pictures of me and my family. So if anyone could please help me I would be really happy. Sorry for rambling and have a good day. :)
  2. Designer
    Designer Been spending a lot of time on here!
    Apr 13, 2012
    16,086
    4,028
    Iowa
    VR came before VRII, which was some improvement, but your budget may dictate which one you get.
    I think you should get the AF-S 18-55, and either VR or VRII. A used example should be fine if it has not been abused.
    I had that lens on my camera most of the time for the first several years. I hardly ever used the 55-200 so I traded it away last year.
    The AF-P is a later model, and will be priced accordingly.
    There are many other choices as well, so depending on what your "photographic style" is, you could also get a 35mm or a 50mm or even something a bit longer if you like to keep some distance from your subjects.
  3. lunars
    lunars TPF Noob!
    Dec 3, 2017
    5
    On the Nikon website the AF-S 18-55mm VR II is way cheaper than the AF-P 18-55mm VR, like a 400 reais (brazilian coin) difference. Does it has anything to do with the automatic focus?
  4. Dave442
    Dave442 No longer a newbie, moving up!
    Feb 1, 2015
    1,681
    387
    I would go with the first lens in your list.
  5. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,028
    15,012
    USA
    Yes, the AF-P uses a _new_ autofocusing system, which currently, the D3100 is not able to use. Only the very-newest Nikon bodies can utilize the AF-P lens models, so the AF-S VR or AF-S VRII versions of the 18-55 would be the right lens for your camera. Either of those two would be fine.
    I like the VR lenses from Nikon.
  6. dunfly
    dunfly No longer a newbie, moving up!
    Jan 26, 2016
    109
    32
    I would try to find a good price on a Nikkor 18-140 mm DX AF-S. It is a better lens and has more range. Amazon has a refurbished on for about $265.
  7. lunars
    lunars TPF Noob!
    Dec 3, 2017
    5
    My camera actually came with the AF-P and I was scared of buying an AF-S and it not being compatible. But I guess I will go with the AF-S then. Thank you!
  8. otherprof
    otherprof TPF Supporters Supporting Member
    Nov 19, 2011
    1,621
    945
    Long Island, New York
    The MPB ad on this site has an 18-55 afp listed as like new for $75.
  9. Derrel
    Jul 23, 2009
    40,028
    15,012
    USA
    AF-P was not invented during the time the Nikon D3100 was made...
  10. ac12
    ac12 TPF Noob!
    Dec 5, 2017
    48
    5
    Personally I would go with a 18-140.
    That way, the ONE lens will do 95+% of what you want, and you avoid the hassle of changing lenses.
    BUT, the 18-140 is larger and heavier than the 18-55, which would make the small and light D3100 camera bulkier and heavier. That may be a significant consideration. There is no free lunch.
  11. SquarePeg
    SquarePeg Hear me roar Staff Member Supporting Member
    Mar 18, 2013
    5,016
    2,808
    Boston
    I would look for a used/refurbished 18-105 with VR. It's a great "kit" lens and covers a bigger range than the 18-55 kit. You don't want the 55-200 as your only lens.
    Refurbished AF-S DX NIKKOR 18-105mm F3.5-5.6G ED VR from Nikon
