Help taking photos around glass
Discussion in 'Digital Discussion & Q&A' started by eclipse13, Sep 25, 2008.
  1. eclipse13
    eclipse13 TPF Noob!
    Feb 19, 2008
    88
    Wilmington/Greenville, NC
    I am photographing a wedding next month and the reception is at an aquarium. The bride wants some 'fun' shots around the fish and shark tanks. I'm worried about the flash. I'll have a f/2.8 lens with me, but I'm sure I'll need my flash anyways. What would you recomend being the best way to avoid a bad reflection from the glass on the tanks? I've got a speedlight that swivels every which way to I can aim it wherever I need to.
  2. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,965
    14
    Durham, UK
    If its similar to the aquarium I did a job in you'll have problems, I was only shooting 1 person and had to bin several shots, though this was in film days and the site itself was very dark with tanks lit from above, go for tight angles if possible. H
  3. eclipse13
    eclipse13 TPF Noob!
    Feb 19, 2008
    88
    I've ever been there, but I'm picturing the same thing. The bride says that it is pretty dark.
  4. Big Mike
    Dec 16, 2003
    33,876
    1,826
    Edmonton
    Get the flash off of the camera...far off. That way you should hopefully be able to avoid any direct flash reflections coming off the glass and back to the camera. Not only that, but off camera lighting is probably the best thing you can do to improve your photography (if you were not doing it already).
  5. eclipse13
    eclipse13 TPF Noob!
    Feb 19, 2008
    88
    Well for the ceremony it'll be little to no flash. I'll be using an SB-800 for the reception. I can use that off of the camera though. Thanks for help.
  6. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
    this might sound basic - but get a friend or two and take you kit and go play in the aquarium - if its a touristy place phone ahead and see if they have a closed day you can get in or a period of quite - that will at least get you some experience shooting in the differnet environment
  7. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    A couple of ideas:
    1) f1.8 lens and high isos + noise correction done in noise ninja or something similar
    2) Bounce the flash off the ceiling, while blocking it from the front with a thick black notecard attached to the flash with a rubber band. This will still likely require a fast lens and higher then normal iso's because most aquariums have dark ceilings.
  8. eclipse13
    eclipse13 TPF Noob!
    Feb 19, 2008
    88
    I have a F/2.8 that I could try. I thought about blocking the flash, just didn't know how. I might give the black card thing a shot.
    Thanks
  9. Kaleighx
    Kaleighx TPF Noob!
    Jul 17, 2008
    39
    Boston, Massachusetts
    Would you mind posting the pictures? (your favs) i wanted to do a similar shoot and would love to see your take on how you did it!
  10. eclipse13
    eclipse13 TPF Noob!
    Feb 19, 2008
    88
    Sure. The wedding in next Saturday, the 11th, so it'll be sometime after that.
  11. Kaleighx
    Kaleighx TPF Noob!
    Jul 17, 2008
    39
    Great! I look foward to seeing them :]
