Help Transitioning to FX in Stages
Discussion in 'Nikon Cameras' started by Chopster01, Nov 7, 2017.
  1. Chopster01
    Chopster01 TPF Noob!
    Nov 7, 2017
    16
    I have a Nikon D7200 and a couple of DX lenses, but I want to move up to FX. Economically I could only do this in a couple of stages. Here are three possible first steps I am considering. Is one clearly better than the others? Is there one I haven't thought of? I primarily shoot street, people, and events that often have difficult or low light. I do some landscape, too. Not a professional, just a very avid amateur, and don't do studio work.
    These three first-step options each cost about the same, within a couple hundred bucks:
    1. Buy a D750 with a kit 24-120 f4 lens (versatility, but a slow lens).
    2. Buy a D750 with a 35mm f1.8 lens (less versatility, but a fast lens.
    3. Go for glass first and buy the 24-70 1.8 VR lens, which can be used cropped on my D7200, and get the D750 as Step 2.
    Thoughts? Other options? All help appreciated.
    Charlie
  2. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    22,737
    8,137
    Iowa
    "Slow" lenses are becoming less and less of an issue these days given the ability of modern DSLRs and software to deal with high ISOs.
    • Agree Agree x 2
    • Like Like x 1
  3. Chopster01
    Nov 7, 2017
    16
    Thanks! So are you recommending my first option?
  4. 480sparky
    Mar 8, 2011
    22,737
    8,137
    Iowa
    If you think 24-120 will work for you, go for it. I found it too short so I upped to the 28-300. I think it's a helluva lens. I have D600s, so the D750 would be even that much better.
    • Like Like x 1
    • Informative Informative x 1
  5. Chopster01
    Nov 7, 2017
    16
    I'll check that out. Thanksagain.
  6. astroNikon
    astroNikon 'ya all Bananas I tell 'ya Supporting Member
    Aug 15, 2013
    13,360
    3,241
    SE Michigan
    What is a 24-70 1.8 VR lens? as in ONE point EIGHT ?? Do you mean the 24-70/2.8 lens?
    just remember all FX lenses work on DX cameras.
    When I first bought my D7000 I only bought FX lenses after the initial kit lens.
    I then bought a D600, and now use a D750 as my primary camera.
    You might as well make the jump with #1 if you have the funds.
    What are you going to do with the D7200 ? Are you going to keep it or is it going to help fund the transition?
  7. Chopster01
    Nov 7, 2017
    16
    Typo. Sorry. Wouldn't it be nice if there was a 1.8 version?
    I'm a little confused. You say you yourself bought FX lenses to use on your DX body (sounds like #3 to me) first, then upgraded the body, but you recommend option#1, buying the D750 with the kit lens. The cost of each option is about the same right now, so that part is about equal. In the end, do you feel that's better than what you did?
    At first I will keep the D7200 and the lenses as backup, but would contemplate selling them after I take the plunge, either to help offset the sticker shock or help finance my next step.
  8. benhasajeep
    benhasajeep No longer a newbie, moving up!
    May 4, 2006
    4,021
    494
    You can use DX lenses on the D750! Unless your selling everything to buy the D750. You can still have some lenses to use. Just the output will be in DX mode on the camera.
    • Like Like x 1
  9. astroNikon
    Aug 15, 2013
    13,360
    3,241
    SE Michigan
    I bought a D7000 with the kit 18-105 lens
    Then I bought a 50mm/1.8 AF-D lens.
    then (some of which I bought maybe in the order I bought them) ..
    24-85 / 2.8-4.0 AF-D
    80-200/2.8 AF-D
    18-35 AF-D
    then other lenses. By buying AF-D lenses I used the in-body motor for Autofocus and saved tons of money compared to the modern AF-S lenses. For my purposes it worked out great.
    Then I bought a refurb'd D600 before I bought the 18-35. But I would have gone a D600 - 24-120 bundle if I could have afforded the bundle.
    It all depends upon your budget.
    Mine was small incremental steps.
    By going to the 24-120 you'll learn more about your shooting habits (at what focal length you shoot).
    Plus, I needed the FX s 2 stops faster at low light than DX for astrophotography work. So the camera body was a bit important to me. I also do sports, but back then it was smaller kids fields so focal length wasn't a problem with the 80-200. Now on a full size field I'm thinking of a 70-300 AF-P as the 150-600 is overkill as I'm at 150-300 on it with the 150 too long. On the D500 I had the 150-600 I was at 150 - 200 .. so the 80-200 worked better. But still with 80x1.5 it was still too long on the short end.
    • Like Like x 1
  10. Chopster01
    Nov 7, 2017
    16
    So far this seems to be the most recommended course, FX body first with slower kit glass rather than fancy glass first with FX body later. Thanks.
  11. WayneF
    WayneF No longer a newbie, moving up!
    Oct 11, 2013
    573
    104
    Texas
    The 24-120 mm is a fine general-purpose walk-around-all-day-with-one-lens solution. Equivalent on FX of the 16-85 mm on DX (maybe better). The new models have plenty of ISO performance, and three more EV of ISO makes it match a f/1.4. That has not been an issue, even in the dark European cathedrals. :)
    I have the three f/2.8 lenses including the 24-70, and I use them at home. A f/2.8 lens at f/4 performs a bit better than a f/4 lens at f/4. But they are heavy, and I take only the one 24-120 on extended trips like one or two week cruises or tours. It has never disappointed. I also have a 50mm f/1.8 which I have absolutely no use for.
    • Like Like x 1
  12. ac12
    ac12 No longer a newbie, moving up!
    Dec 5, 2017
    375
    118
    I would go with the D750 + 24-120 f/4 zoom.
    Or if you plan a 2 lens kit (24-70/2.8 + 70-200/2.8), then get the D750 with the 24-70/2.8 first.
    Or a D750 + 50/1.8, then later the 24-70/2.8. The 50/1.8 is a good FAST lens to have.
    But the D750 + 24-120 kit is 33% heavier than the D7200 + 18-140. So I opted for the lighter D7200 option. On a LONG shoot, a heavy camera+lens will feel heavier and heavier as the day (or days) goes on. In fact there are times that the D7200 kit feels heavy, and I want a lighter kit.
    IMHO, unless you NEED the features of the current FX bodies, the high end DX bodies like the D7200 is good enough for most of us.
