HELP! Trouble with slow shutter speed in afternoon daylight!
Discussion in 'Photography Beginners' Forum' started by smackitsakic, Mar 29, 2010.
  1. smackitsakic
    smackitsakic TPF Noob!
    Mar 21, 2010
    246
    8
    Saskatchewan
    Greetings!
    I am still quite new to photography (had my first DSLR for just over a month now) and wanted to take some pictures of some massive windmills near my city of residence.
    My wife and I made the 20 minute journey to the windmills. My intention was to capture these windmills using a slow shutter speed to give a motion effect for the windmills with a still background.
    Anyway, I slowed down the shutter speed to 2 seconds, set the aperture to f-32 and the ISO to 100, the biggest settings my equipment could handle. The images came out incredibly over-exposed, to the point where the images were white and nothing but white. The only thing I could do to have the images correctly exposed was accelerate the shutter speed, which defeated the purpose of me trying to shoot these windmills in motion.
    What did I do wrong and what I can do differently next time? Any help for this new photographer would be greatly appreciated!!
  2. m.stevenson
    m.stevenson TPF Noob!
    Mar 20, 2010
    50
    Lander, WY
    unless the wind mills are going super slow I would defiantly speed up your shutter speed. I will limit the amount of motion but 2 sec of a good moving wind mill is quite a bit of movement and less time will defiantly capture what you are looking for.
  3. jensgt
    jensgt TPF Noob!
    Nov 21, 2009
    242
    16
    Bowie, MD
    2 seconds is way long. You can capture motion at a much quicker shutter speed than that. Only other option would be adding a ND filter to darken the scene allowing the slower shutter speed but 2 seconds is probably still too long. You can see motion at speeds like 1/60.
    Also you did not mention using a tripod...hopefully you were.
  4. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    It sounds like you completely ignored your camera's light meter. Hence, the extreme overexposure. You can't just pick the settings you want, you need to be mindful of the exposure...and in this case, there was too much light to shoot that slow...even with your smallest aperture and lowest ISO.
    The easiest thing to do, would be to shoot at a different time of day, when it's not so bright...but you could also add ND filters, which block some light, allowing you to get an exposure with a longer shutter speed.
  5. smackitsakic
    Mar 21, 2010
    246
    8
    Saskatchewan
    At the risk of sounding totally stupid, which i'm willing to take being that i'm new to this...what the heck is my camera's light meter?
    By the way, love the avatar Big Mike - stellar Oil jersey!
  6. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    Your light meter tells you if your exposure is correct or not when using manual mode.
    If you want to take long exposures in the daylight you'll need a ND (dark) filter on your lens--think of it like a pair of sunglasses for your camera.
  7. Gaerek
    Gaerek TPF Noob!
    May 2, 2009
    1,341
    98
    Sitka, AK
    Try this:
    Put your camera on a tripod. Compose your shot. Switch to Av mode, and set your aperture to the smallest possible. Then turn your ISO the lowest possible. What shutter does the camera recommend. If it's faster than say 1/30, you probably won't get the effect you want. You'll need to shoot at a darker time of day, or pick up a Neutral Density filter (as others have said). No need to shoot manual for this.
  8. Dominantly
    Dominantly TPF Noob!
    Jul 30, 2009
    3,032
    166
    San Diego, CA (RB)
    VVVV Down there is a link with photos of it.
  9. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    Buy this [ame="http://www.amazon.com/Understanding-Exposure-Photographs-Digital-Updated/dp/0817463003"]book[/ame] and read it. When you understand the triad that goes into exposure, these situations will not happen.
  10. Tee
    Tee Been spending a lot of time on here!
    Mar 26, 2010
    1,953
    619
    South central PA
    *Not meaning to threadjack*
    Thank you for that tip, Gaerek. I ran into the same problem as the OP this weekend while trying to slow-mo water in a fountain (camera kept saying "subject too bright", I was trying to ignore it like a toothache :D).
    Quick question: is there an unwritten (or written) rule about avoiding certain times of the day? I've read a few posts that suggest avoiding high noon. Aside from a ND filter, are there any other tricks when coming back at an earlier/ later time in the day isn't possible?
    gryphon: thanks for the link. Book ordered.:thumbup:
  11. burstintoflame81
    burstintoflame81 TPF Noob!
    Aug 7, 2009
    729
    Arizona
    .....and when you buy an ND filter. Understanding doesn't magically make your camera operate differently. If you want a long exposure in super bright mid day light, you will need an ND filter. There isn't some magic setting on your camera that will change that. It acts as a sunglass basically. The camera can still see the image, but you can open and allow light in more slowly so that you can capture motion without blinding your camera sensor. Often used to get that swirly magical look to flowing water.
    That doesn't mean you shouldn't learn exposure though. If you knew exposure, you would have known how to fix your problem already so it would have saved you a lot of time :)
  12. KmH
    Apr 9, 2009
    40,565
    5,548
    Iowa
    You'll find a description of it and it's location in your camera by reading the users manual that should have been included with your camera.
    If you don't have the users manual you can download one at the web site of the company that made your camera.
shooting slow shutter speed in day light
slow shutter at day time shows too much light
