- Joined
- May 1, 2008
- Messages
- 25,418
- Reaction score
- 4,999
- Location
- UK - England
- Website
- www.deviantart.com
- Can others edit my Photos
- Photos OK to edit
I would say its one of two possible problems
1) duff memory card
2) duff/dirty sensor.
The first is easily tested and you cna do that by formatting the card in camera (not in the computer). Then see if the shots keep repearting the effect. If you have a second card try using that instead as well.
2) If its dirt on the sensor (like oil possibly from internal components squirting a bit onto the sensor - the 5D had this problem) then you can have it professionally cleaned out (best done since oil is a swine to get of well). However I would rather send thecamera off for a proper servicing in this case otherwise your likley to end up spending even more should the clean not prove effective (unless you have a friend who can clean the sensor well for you)
1) duff memory card
