Help, why are my pictures so blurry?
Discussion in 'Photography Beginners' Forum' started by page_tyson, May 6, 2010.
  1. page_tyson
    page_tyson TPF Noob!
    May 4, 2010
    65
    Provo Ut
    Here are some pictures I took today of some friends. I'm kinda bummed cause almost every picture is out of focus. Here's what I took the pictures with, Canon Rebel xs 10.1 mp, and a canon 50 mm 1.8 ef lens. I know I'm doing something wrong here but don't know what. I try to focus on faces (typically around the eyes). Is there a setting on my camera that I should be aware of? or Is there something wrong with my auto focus? I've only had the camera for a few months now and am just not getting the results I would like. Does this blurriness come from user error or lack of quality equipment? I can't for the life of me take a crystal clear picture. I took these pictures at f1.8 and Iso 200. Is the ISO set too low? Even the pictures taken from a tripod are not in focus. (These pictures have not yet been photoshoped)
    IMG_5950.jpg picture by page_tyson - Photobucket
    IMG_5954.jpg picture by page_tyson - Photobucket
    http://s809.photobucket.com/albums/zz15/page_tyson/?action=view&current=IMG_5955.jpg
  2. vansnxtweek
    vansnxtweek TPF Noob!
    Apr 27, 2010
    171
    Virginia
    I see what you mean. Have you tried using the manual focus function to focus exactly where you want? Maybe go into the P mode on the camera that way it still chooses the shutter speed and aperature value but you have a bit more control over focus.
  3. kelli_anne
    kelli_anne TPF Noob!
    Apr 13, 2010
    127
    Chicago IL
    I would use manual focus for these types of shots. If this was moving kids then that would be a different story! There should be different focus settings on your camera. The ISO should have nothing to do with the blurring. 200 is a fairly low number, the higher the number the more nosie a photo can have, this is not nosie this is focusing problems. I would read through your camera user manual and see what it says on focusing. I always find that I get better results when I focus myself.
  4. Fedaykin
    Fedaykin TPF Noob!
    Mar 30, 2010
    426
    San Juan, PR
    Try either using your AF points instead of full auto AF or Manual focus. In that first picture for example you could have chosen the second to left most AF point on your XS and placed it over her eyes, that should have gotten a good focus. If you were shooting wide open try stopping down to say f/5.6 so you have a larger DoF to work with.
    If you don't want to have to manually select your AF point(it's actually very easy and fast to do and right in the viewfinder) or use MF you could just use AF point selection and leave it in the center point; focus on your subject by placing it/him/her right in the middle and half-pressing the shutter, then leave it half pressed, recompose and take the shot. problem with this is it's not always spot on and you're still moving your lens somewhat, so I recommend manually selecting you AF point if you can.
    Hope that helps.
  5. ghpham
    ghpham TPF Noob!
    Dec 16, 2007
    535
    Looks like the problem is that the camera is choosing its own AF point instead of you. If you take a look at the third photo for instant, you will see the girl's jean and to some degree, the bridge they were on is pretty clearly focused.
  6. page_tyson
    May 4, 2010
    65
    Provo Ut
    That's why it's so frustrating. I always select the focus point. Anyway thanks for the suggestions. I'll try stopping down to around 5.6 and see if it helps. I love the DOF I get at 1.8-2.2 and the amount of light it gives me, doing so just doesn't give me the consistency that I would like. As far as equipment goes I should get better results though right?
  7. Goontz
    Goontz TPF Noob!
    Jul 17, 2009
    1,275
    Austin/Houston, TX
    The DOF is so narrow at those large apertures that even using a focus and recompose method can throw your intended focal point out of the DOF. You have to be very careful how much you move the camera when recomposing. That could be the problem here.
  8. bazooka
    bazooka No longer a newbie, moving up!
    Dec 28, 2009
    2,293
    294
    Houston
    Also note that the 1.8 is quite soft at 1.8. Stopping down will help with overall sharpness.
  9. DerekSalem
    DerekSalem TPF Noob!
    Aug 8, 2009
    660
    10
    Cleveland, OH
    At f/1.8 the dof is literally probably only an inch or 2 at that distance (second pic). Decrease aperture size but also just use the center focus point. It's usually the most accurate of them. Lock focus then move the viewfinder where you want.
    And it's not a movement blur problem it's just an out of focus problem with possibly some softness from the camera body
  10. KmH
    Apr 9, 2009
    40,751
    5,588
    Iowa
  11. mwcfarms
    mwcfarms No longer a newbie, moving up!
    Mar 16, 2010
    2,656
    179
    Southern Alberta
    Im not sure if Canons software has this option or not but this has helped me somewhat in my focusing. In the Nikon software you have the option to see what your camera actually focused on once you've downloaded them to the computer. If you go out take a few shots write down what you think you were focusing on and then checking again see how off it is. Im not sure if Canon does but it helped me a bit. Good luck.
  12. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,144
    2,945
    Chesterfield UK
    Your setting are all to cock, at that distance you should have been at F8, iso was too high at iso400 which gave you a shutter speed of 1/4000, don't use F1.8 for shooting outdoor portraits nowhere near enough DOF
blurry photos with nikon d90
how to use nikon d90 blurred pic
my nikon d700 photos comes out blurry
my photos come out blurry on my nikon d700
nikon 700d photos are blur
nikon d700 blurry pictures
nikon d700 pictures blurry
nikon d90 blurry pictures
pics by d90 blur photography
why image from nikon d90 blur
