Help With Canon DSLR Lens?
Discussion in 'Photography Beginners' Forum' started by Buszaj, Jun 17, 2007.
  1. Buszaj
    Buszaj TPF Noob!
    May 23, 2007
    521
    Toronto
    Hi everone,
    I'm sort of thinking about a DSLR camera. Would like to get a Canon, probably XTi. Found a good deal at Futureshop. The kit has the camera, a 75-300 and 18-55 lens, I would also like to get a third. I really like to shoot wildlife and sports. My budget is around $600 Canadian. Preferably a Canon lens. Any help really appreciated.
    Thanks a lot
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Welcome to the forum.
    For beginners, the 18-55 and 75-300 should be OK. They are not top quality lenses...but they should be a good kit to start with.
    For shooting wildlife, usually you want a longer lens. For sports, you usually want something fast (large maximum aperture) and probably something long as well. The trouble is that fast and long together makes for a very expensive lens....closer to $6000 than $600.
    I would suggest that you try out those two lenses for a while and see how you like them. The 75-300 may be all you need for shooting wildlife and even sports.
    I there is something missing from those two lenses...it's a fast lens for shooting in lower light. There are several good options to fill this void. The Sigma 30mm F1.4 is a great quality lens and very fast. The Canon 50mm F1.8 is very cheap and has good image quality. The Canon 85mm F1.8 is a great lens and isn't all that expensive.
    You might want to get a flash as well...in which case, I'd suggest the 430EX. The flash and a cheaper lens should fit your $600 budget.
    Also, if you get the camera without the 18-55 kit lens, you could get a better lens for that range. The Canon 17-85 IS, lens is a good choice. The IS (image stabilization) is a great feature. Alternatively, the Tamron 17-50 F2.8 is a great lens.
    You could also consider the Canon 75-300 with IS, which is a fair bit more expensive than then 75-300 without IS...but again, it's a great feature.
    Future shop does have great deals from time to time...but I'd also consider ordering from B&H or Adorama (links at top of page).
