Help with fill flash.
Discussion in 'Beyond the Basics' started by NEPats37, Apr 12, 2007.
  1. NEPats37
    NEPats37 TPF Noob!
    Feb 10, 2007
    76
    Rhode Island
    I have the basic idea of fill flash down but wanted to touch up a little. Lets say I want to use fill flash outdoors on a sunndy day. How exactly can I do this so it does not over expose the picture? do I go close the aperture one or 2 stops from the recommended aperture without flash?
    example without flash 1/125 f8
    fill flash 1/125 f11?
    thanks for the help.
  2. zioneffect564
    zioneffect564 TPF Noob!
    Feb 24, 2007
    309
    Dallas/Ft. Worth, Texas
    First off what flash are you using? For the most part you will not over expose the picture if its a sunny day. I would try going to down 1 stop but i'll let the more experienced people fill in the rest
  3. NEPats37
    NEPats37 TPF Noob!
    Feb 10, 2007
    76
    Rhode Island
    i have 2 flashes, a sunpak completely manual flash that I hate, the other is a auto canon speedlite, you just tell it how far away and it does the rest.
  4. zioneffect564
    Feb 24, 2007
    309
    Well somethings you might try is standing a little farther back and/or diffusing it. Just a suggestion though...
  5. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    What's your flash sync? Adjust your shutterspeed, ISO, aperture, whatever for the ambient exposure to match your flash sync. Fill flash just fills in your shadows. TTL metering pretty much does that for you anyway to keep from blowing out what the sun is already shining on.
  6. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    Manual fill flash was always the most difficult thing in photography for me. In bright sunlight with backlit subjects, I used to calculate a normal flash exposure and stop down one stop from that. It was usually in the ball park. With modern automated TTL flash it is as easy as it used to be difficult. The camera just does it for you. Try my original rule of thumb. It should get you close enough.
