help with gimp
Discussion in 'Photography Beginners' Forum' started by danherz, Aug 20, 2006.
  1. danherz
    danherz TPF Noob!
    Aug 8, 2006
    31
    downtown
    how do you keep somethings one color and change the rest of the image? im trying to change the background to b/w and keep the subject in color but i keep screwing it up! thank you
  2. darin3200
    darin3200 TPF Noob!
    May 3, 2005
    2,078
    28
    Des Moines, Iowa
    Google for some guides for 'selective coloring'
    Basically make a copy of the layer. Make the bottom one B&W and the top one color. Then erase anything in the top layer you don't want to be color
  3. Tiberius
    Tiberius TPF Noob!
    Jun 19, 2006
    328
    Michigan, USA
    I'd do it slightly differently:
    Create a Duplicate Layer on top and convert the top layer to B/W through your method of choice (Desaturation or otherwise). Put a layer mask on the top level and then use whatever brush you want to "draw" in the area you want colored.
  4. danherz
    danherz TPF Noob!
    Aug 8, 2006
    31
    downtown
    thanks guys ill give it a go, this is probably a dumb question but what does a "layer mask" do
  5. danherz
    danherz TPF Noob!
    Aug 8, 2006
    31
    downtown
    im siked that works mint!!!
    [​IMG]
  6. darin3200
    darin3200 TPF Noob!
    May 3, 2005
    2,078
    28
    Des Moines, Iowa
    Looks nice. You can also go into the Layer -> levels menu on the B&W and increase the contrast. Try making the blacks blacker.
  7. Tiberius
    Tiberius TPF Noob!
    Jun 19, 2006
    328
    Michigan, USA
    A layer mask is used to only make selected parts of a layer visible. When you first create a layer mask, it's solid white, blocking the entire layer. When you do anything to the layer, the darker parts of the layer become visible. It's kind of like putting a piece of paper over the layer so you can't see it and then cutting holes in the paper.
  8. morydd
    morydd TPF Noob!
    Apr 19, 2006
    499
    Chicago
    I sometimes find it helpful when doing the mask to put a semi-transparent solid color layer between the color and B&W layer to make it very easy to see what's masked and what's not.
  9. zombiekilla
    zombiekilla TPF Noob!
    Jul 31, 2006
    363
    Wisconsin
    a nice site to check out is good-tutorials.com
    you can learn quite a bit from there!
