help with lenses
Discussion in 'Photography Beginners' Forum' started by duello, Oct 12, 2007.
  1. duello
    duello TPF Noob!
    Oct 12, 2007
    NH
    I'm using a Pentax K1000, and I want to buy a zoom lens for it. My camera takes a 50mm diameter lens, but most of the used lenses I’m seeing listed online are either larger or smaller than this. Now I’ve read that all pentax k mount lenses and k-mount cameras are compatible, but does this apply to the size variation as well?
  2. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    there's no difference in diameter. How'd you even find out the diameter anyways?
    Just use the k-mount lenses and you'll be fine.
  3. Big Mike
    Dec 16, 2003
    33,852
    1,817
    Edmonton
    Welcome to the forum
    I'm guessing that the 50mm you are seeing on your lens...is the filter thread diameter (or possibly the focal length) not the mount. As mentioned, it's a K mount, so any lens with a K mount will work.
