help with long exposure shot
Discussion in 'Beyond the Basics' started by polkaisrad!, Nov 14, 2005.
  1. polkaisrad!
    polkaisrad! TPF Noob!
    May 25, 2005
    25
    Kalamazoo, MI
    http://www.thephotoforum.com/forum/showthread.php?t=34505
    ok so this picture right here is a very nice example. Everytime i do this the image of the person fades every time i hit my flash. I usually do it in pitch black (hear it works the best) and use a tripod obviously. Then hold the shutter open and hit the flash for each position. Should I be doing this different?
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    If you are doing this with multiple flashes...there has to be no background...otherwise the background will expose through the previous positions with every flash.
    The way I would do it, would be to use a digital camera (or scan film) and take multiple photos and use photoshop to combine them. Use one as your base and then add the others as layers in Photoshop. Then erase (or better yet, mask off) everything but the new position...in each layer except the background.
    You should be left with one background and a bunch of subjects.
  3. Meysha
    Meysha still being picky Vicky
    Feb 21, 2005
    4,152
    58
    Yep that's right. So long as your flash isn't going to be overexposing the background with all these flashes you'll be alright.
    I've seen a great example of this with a girl on a swing set and the flash was fired about 5 times during the exposure and she's in 5 different positions. The photo was taken during the dark nighttime, so that the girl was too visible between flashes and didn't blur the photo. And the background was far enough away so that it wasn't overexposed, but it was slightly visible.
