Help with making sports pictures crisp..
Discussion in 'Photography Beginners' Forum' started by iPwnF00lz, May 9, 2009.
  1. iPwnF00lz
    iPwnF00lz TPF Noob!
    Aug 24, 2008
    81
    Oswego/Ithaca/ElmiraNY
    I took some shots at my schools lacrosse game the other night and they all came out pretty blurry and not in focus, I used the sports setting on my D70 and I am using a 70-300mm lense. Any tips?:confused:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    See what I mean?:thumbdown:
    I was using a monopod too.
  2. rubbertree
    rubbertree TPF Noob!
    Sep 7, 2007
    727
    Canada
    yes, don't use the sports setting.
    Set it to aperture priority and open the lens right up, as low a number as you can. f/2.8 would work great in these conditions, it looks a little dark and this will give you a quick speed for your shutter.
  3. Sherman Banks
    Sherman Banks TPF Noob!
    Feb 24, 2009
    871
    Rain City
    Chances are your lens is too slow, especially at the focal length you're shooting at. To get shots like these in focus with low lighting, you'd need an aperture of around f2 so you could increase your shutter speed and still retain the same amount of light. Of course you could also bump your ISO up to 1600 or 3200 but the noise levels often negate any quality you gain in focus. And it probably wouldn't buy you as much light as a faster lens would.
  4. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    6,183
    940
    Woodbridge, Ontario, Canada
    The Sports mode will make higher shutter speeds a priority over the aperture.
    Your shots appear to be taken at 1/25s ... way too slow to stop motion blur.
    This means your ISO is too low for the maximum lens aperture and lighting condition.
    You can crank your ISO higher (if you can) ... and/or get a faster lens.
  5. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,144
    2,945
    Chesterfield UK
    If you check the exif and shutter speed that could give you a good clue :lmao:
  6. dxqcanada
    Dec 4, 2008
    6,183
    940
    In the future ... please only post your question once.
  7. iPwnF00lz
    iPwnF00lz TPF Noob!
    Aug 24, 2008
    81
    Thanks very much for your help guys
  8. anubis404
    anubis404 TPF Noob!
    Apr 5, 2008
    955
    First off, use manual mode for best results. Your main problem is probably your lens. The 70-300 is a very slow lens. I would recommend an 80-200 F2.8 or even a 70-200 F2.8VR if you can afford it.
  9. TJ K
    TJ K No longer a newbie, moving up!
    Sep 9, 2008
    2,093
    Sunny South Florida
    Did you read the post he used the 70-300mm that doesn't have 2.8
  10. rubbertree
    Sep 7, 2007
    727
    Canada
    haha! So? I didn't say that lens had it, I was suggesting to use that aperture. Which in this case would mean a different lens. I'm sure he understood that.
  11. SrBiscuit
    SrBiscuit TPF Noob!
    Apr 22, 2008
    2,721
    44
    NH
    i was also going to suggest new lens.
