Help with my polarized filter
Discussion in 'Photography Beginners' Forum' started by almaass, Feb 11, 2009.
  1. almaass
    almaass TPF Noob!
    Jan 26, 2009
    70
    Richmond, VA
    Can someone give me some tips or advice on focusing and what I should be seeing when I rotate that filter? Thanks
  2. bjorkfiend
    bjorkfiend TPF Noob!
    Dec 5, 2008
    301
    Bowling Green, MO
  3. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    I really doesn't make much difference unless you are outside under the sun...and it works best at 90 degrees to the sun's rays. It can also cut down on reflections off of things like glass or water.
  4. blash
    blash TPF Noob!
    Nov 19, 2008
    599
    Generally just focus as you normally would, then rotate the polarizer. CP's are used for:
    1) Eliminate reflections - focus on the surface of the water/metal/glass, then rotate until the reflections are gone. Remember, with an SLR, what you see in the viewfinder is what you get.
    2) Darker sky - same thing, focus on your subject, then rotate the filter until the sky is the color you want it at.
  5. almaass
    almaass TPF Noob!
    Jan 26, 2009
    70
    Richmond, VA
    thanks....
