Help with Noise Ninja
Discussion in 'Photography Beginners' Forum' started by Turnerea, Sep 20, 2008.
  1. Turnerea
    Turnerea TPF Noob!
    Aug 28, 2008
    212
    SoCal
    I just started taking my first shots with my new RebelXTi, and I wanted to try and do some noise reduction on the image below. It was getting dark so I bumped up the ISO so I could still handhold for another few shots, and i wanted to see if I could bring out the detailed colors in the duck- maybe there is just too much noise, but I'm using the profile for my camera on the NoiseNinja website, and am following the help guide with the software, but nothing is happening.... can't get any reduction.
    I downloaded the image (RAW) to Lr, then burned a JPG copy from that, and that is what I'm using to try and do the noise reduction. The software wouldn't open the RAW file- is that my problem??
    Thanks for any help
    [​IMG]
  2. Drake
    Drake TPF Noob!
    Nov 19, 2007
    684
    10
    I maybe wrong, but it looks like even after you bumped up the ISO, the duck was still very underexposed. When you bring out details from shadows, you can end up with lots of noise. As for Noise Ninja, it the image might be a problem for it. The amount of noise differs. There is very little (none?) noise in the water and a lot of it on the duck. The auto detection of noise in Noise Ninja scans the image (most likely) the water part and finds no, or just some of the light noise, leaving the heavy noise on a duck (which is a ery tiny part of the image) untouched. I don't use Noise Ninja (I've got Neat Image), but I think you should mess with the settings a bit more.
  3. toofpaste
    toofpaste TPF Noob!
    Jul 11, 2008
    1,202
    Earth
    OMG! Holy Noise Batman!
  4. Resin42
    Resin42 TPF Noob!
    Jul 16, 2008
    376
    Glasgow, Scotland
    I had a look with CS3's own noise reduction and it does take the noise down slightly but not much. The problem is there's virtually no detail to sharpen in the duck and the reduction only makes this worse. I think you're on to a loser here mate.
  5. Turnerea
    Turnerea TPF Noob!
    Aug 28, 2008
    212
    SoCal
    Thanks everybody- guess I overestimated what Noise Ninja could do
  6. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    Well, Noise Ninja works great, but the problem here (as others have said) is you severely underexposed the duck. (mmm... rare duck!) :lol:
    In fact, if you intentionally OVER-exposed him by just a hair it would have likely reduced any noise you would have had in the shot to begin wtih. Slight overexposure of the primary subject in high iso situations will often make it as if you were using a lower ISO.
  7. josealb
    josealb TPF Noob!
    Sep 6, 2008
    23
    You could also try to rise the exposure from the raw file before burning the file, and not exporting to jpg but to tiff, which doesn't lose quality in compression, are you sure you applied the noise ninja filter correctly?
  8. Turnerea
    Turnerea TPF Noob!
    Aug 28, 2008
    212
    SoCal
    Thanks for the tips- I've tried the PP tips, but to no avail.
    I'm not 100% sure on one step in the Noise Ninja process- when you profile the image, what exactly is happening there? It usually creates a box that does not encompass where the noise is at all. I've done one sunset picture perfectly, and the same thing happened after the profile, so I don't think this is a really bad thing, but maybe its making this duck picture worse??
    Thanks
    Erik
  9. manaheim
    Sep 2, 2005
    14,394
    3,262
    Again, I think the duck pic is underexposed. Noise ninja won't save you from underexposure.
  10. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    You guys!
    He hacked the Rebel to allow ISO 25600!
  11. manaheim
    Sep 2, 2005
    14,394
    3,262
    :lol: Little early to be drinking, isn't it reg? :lol:
  12. toofpaste
    toofpaste TPF Noob!
    Jul 11, 2008
    1,202
    Earth
    ROTFL
