Help with Photoshop CS2
Discussion in 'Graphics Programs and Photo Gallery' started by Stacey, Aug 25, 2007.
  1. Stacey
    Stacey TPF Noob!
    May 31, 2007
    192
    Nowhere, IL
    Couple of questions.....
    Can someone tell me how to do selective coloring?
    How do I lift/move eyebrows/eyes?
    For some reason, I am not picking up on how to use this and it's aggravating to me!
    Any help is always appreciated!
  2. glaston
    glaston TPF Noob!
    Jul 4, 2007
    216
    There are a few ways to do selective coloring.
    What method is best to use depends on your skill level with photoshop.
    Personally, I like to use layer masking because it's non-destructive.
    There's also the simple method of selecting the area/s you want to retain color in and copying them to a new layer. Then you apply an adjustment layer above the original layer to strip out it's color.
    That's a rather archaic method though.
    I'll explain the masking method to you.
    Make a copy of your original background layer, then click off the visibility of the original background layer and select the background copy.
    Add a channel mixer adjustment layer, and put a check in the box that says 'monochrome'.
    On the right of the new adjustment layer, click on the layer mask icon to make it active.
    Go into the channels tab of the layers palette and click on the layer mask channel on the bottom.
    Now select your paintbrush tool and choose a brush suitable for the size of what you're painting out.
    Now use the paintbrush tool with transparent red spray paint to fill in the area where you want to retain color.
    You'll want to zoom in and out alot to paint it with accuracy.
    Now click off the layer mask channel and go back into the layers tab.
    That's it, you can tweak some of the settings all you want but that's the basic method.
    I'm pretty sure I didn't leave anything out.
    Good luck.
  3. dakkon76
    dakkon76 TPF Noob!
    Aug 22, 2007
    464
    39
    Eastern Washington
    Awesome tutorial! I don't have much experience with photoshop yet and I was able to get it to work -- thanks a bunch :)
    [​IMG]
  4. glaston
    glaston TPF Noob!
    Jul 4, 2007
    216
    Glad it was easy enough for everyone to follow.
