help with rule of thirds.
Discussion in 'Photography Beginners' Forum' started by Kathleen, May 9, 2007.
  1. Kathleen
    Kathleen TPF Noob!
    Mar 26, 2007
    121
    Ontario
    I'm a little confused with the rule of thirds. I know that you should imagine a grid somewhat like tic-tac-toe and place the subject on one of the crossing lines. My problem lies with setting it up. Do I focus on the item that I'd like to have as my subject by using the center dot in the viewfinder (lock the focus or hold button) and then shift away from subject, placing it at one of the imagined cross lines? I hope this makes sense.
  2. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    You can focus however you want. Some people manual focus. Some people focus and lock. Some people select an alternate focus point and use that. It's up to you. I always focus first and then compose.
  3. gizmo2071
    gizmo2071 TPF Noob!
    Oct 19, 2006
    861
    Toronto, ONT
    Matt described ways to focus, but about that image you posted.
    If you twisted the angle slightly, you could have got the background flower on the other line of 3rd, I just think that would have made it more balanced :)
  4. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    unless I'm on a tripod I always use my center focus point, lock, and recompose.
  5. MPowerM3
    MPowerM3 TPF Noob!
    Mar 19, 2006
    239
    Ct, USA
    How do you lock the focus on a Canon Rebel Xt, anyone know?
  6. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I'm fairly sure it's in the manual.
    Typically, you press the shutter release button half way down, let it focus and then hold it there until it's time to snap the shot.
    I'm not sure if the Rebel cameras have thumb buttons...*...but on my 20D, I changed custom function #4 so that AF is controlled with this button rather than the shutter button.
  7. MPowerM3
    MPowerM3 TPF Noob!
    Mar 19, 2006
    239
    Ct, USA
    Thanks Big Mike, I guess that was pretty easy huh, back on topic!
  8. Kathleen
    Kathleen TPF Noob!
    Mar 26, 2007
    121
    Ontario
    With your help tucked in my noggin, I just went for a stroll through the woods. Although I'm sure this shot has its faults, I hope that I'm getting the idea of the rule of thirds??
  9. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Yes, you did place the flower on a third, BUT, you have lots of distracting/confusing elements in the photo cluttering it up, most notably in the bottom left corner.
    About the "rule" of thirds. Don't think of it as a rule. Think of it as, "the reason why some photos look good". It's just a suggestion. If the elements in your scene are going to get in the way by using thirds, then you simply don't do it. Every composition has to suit the subject and where/how it's being photographed. Something like this photo might have been better served with a macro.
  10. DeepSpring
    DeepSpring TPF Noob!
    Jul 12, 2006
    1,451
    Los Angeles
    The rebel does have that ability. I personally prefer focus lock to be on 1/2 shutter but you can set it to * if you want
  11. xfloggingkylex
    xfloggingkylex TPF Noob!
    May 5, 2006
    1,292
    Frederick, MD
    same here. My half shutter locks the focus as well as the exposure so what I am focusing on is done right. Of course pressing the exposure lock button prior to the focus lock takes that exposure instead and does nothing when I lock the focus. Locking them both makes recomposing very quick and painless.
    I bring this up because if your camera is only locking focus and then you recompose you run the risk of not exposing for the in focus subject and that can cause problems.
  12. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    that is how i do it .. compose, then point my camera at whatever should be in focus and half press the shutter to focus, then recompose and plopp, take the picture.
    remember the rule of thirds is not really a "rule" .. it is just an idea which works in some cases. if by applying it you create a lot of empty space you have to be careful about that space creating something, if not, then you image might just lose balance in a bad way.
    also it does not have to be thirds always ;) depending on the geometry of the subject, halfs can do it or even sixths ;)
