Help with star trails
Discussion in 'Beyond the Basics' started by invisible, May 22, 2008.
  1. invisible
    invisible Been spending a lot of time on here!
    Mar 10, 2007
    5,213
    977
    Canada
    Tomorrow I'll go out to the lake to try and shoot some star trails. It's going to be my first time doing this kind of long exposures, so I'm hoping some of you can help me out with tips.
    My camera is a Nikon D70s with the Nikkor 18-200 lens. I'm bringing my tripod and my cable release.
    - How many hours of long-exposure shooting will I get with a fully charged battery (EN-EL3a, Li-ion)?
    - What's the longest exposure that the D70s can stand? (I have read about the dangers of overheating the sensor, but I couldn't find data specific to my camera.)
    - I'll probably go the widest possible angle (18mm), to catch some of the surroundings, and definitely go with the minimum possible ISO (200). What aperture/speed do you guys recommend? White balance?
    - What about mirror lockup? Will it make a difference?
    Any other tips will also be appreciated.
    Thanks so much for your time!
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Don't even bother. An exposure longer than about 15 minutes will be so full of noise and dead pixels that it will be almost unusable.
    But that doesn't stop star trails. Just change the technique. Setup your camera aperture wide open or close to it and ISO200, and take a constant series of 2 minute exposures. Make sure long exposure NR is off, so there is no gap in between the photos you take. Then use an image stacking program http://www.tawbaware.com/imgstack.htm to generate a final composite. You will actually get (shock) a usable image. But note your sensor still heats up. Maybe you want to take 1 minute on and 10 second gaps between your exposures. If you zoom in this causes gaps in the star trails but at a wide angle 10seconds won't give you a noticeable gap for any normal sizes (reads as not zoomed at 100%)
    I expect the D70 should get the same time than the D200 so you can get about an hours continuous exposure. 2 with a battery grip. If you split up and add a 10 second gap every 60 seconds of course your total shooting time goes up along with your trail length.
    Ignore mirror lockup. It makes sense only for shutter speeds between 1/30th and 1/2 second. Beyond that the vibration is so small in the final exposure it is not visible.
    Finally I hate to say it to the digital buffs here, but if you really want to take star trails, film camera, bulb cable release. You can go all night without even the slightest concerns for noise or camera damage.
    • Like Like x 1
  3. invisible
    Mar 10, 2007
    5,213
    977
    Canada
    Hey Garbz, thanks for your great input!
    Even though I think I'll stick to traditional long exposure tonight, would you be so kind as to post a couple of pictures of startrails processed with the method you described? Also, if you have some, can you post pictures shot the traditional way, with the noise and dead pixels you said I should expect?
    Thanks again!
  4. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Certainly:
    [​IMG]
    This image was processed from 200 30 second frames. With a 5 second gap between frames. Now the lack of stars come from my light pollution floor. These images were stacked with a MAX algorithm where each image is analysed and the brightest luminance value is taken for the final image. This has the advantage of trailing the stars without increasing the light pollution. Using a standard ADD function to get the equivalent of a 100minute exposure would have resulted in an image probably so blown out it would have been unusable. Even though there light trails show 2 hours of movement, the light pollution I think in the final image came from a 2 minute exposure. (30 seconds made the background unnaturally dark compared to the stars).
    I can't post an example of the other one because the image I got out after a 1 hour exposure was so noisy that after an hour in photoshop with the clone too and trying various filters I totally gave up on it and just deleted it. Take a 15 minute exposure and count the dead pixels, and then remember the number of dead pixels increase logarithmically in time (or close to it based on observation). I am afraid to say but the noise in that final picture I got could probably be measured as a percentage of dead pixels it was that bad.
  5. Cinka
    Cinka TPF Noob!
    May 19, 2007
    235
    10
    Los Angeles
    Wow! That's pretty amazing.
  6. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    Awesome pic, Garb.
    FYI, the D200 is somewhat notorious for being "not so great" on battery life. You may find the D70 will shoot for quite a while. I would spend a whole evening (4+ hours) shooting with my D100 and have no problem at all. (granted, I was moving from subject to subject)
  7. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Continuous exposures are a very different beast. I wouldn't say the D200 is bad by any stretch. With a battery grip I have used my camera for days without actually recharging.
    The 3 components that chew the most power are the light meter, the LCD, and the sensor in order from least to most. When shooting normally most of these are on for no more than 10 seconds at a time before the camera shuts them off and puts itself in idle mode to save power.
    I guarantee your D100 would not 4 hours continuously exposing. Sensors chew a huge amount of juice. Which is why P&S cameras and cameras with live view turned on have a despicable battery life.
  8. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    You'll have a heck of a time attaching a cable release to the D70s. There's no place to connect it! Instead, you should use the ML-L3 wireless release.
  9. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    He'll have to ignore mirror lockup. The D70s, like my D80, supports mirror lockup only for filter cleaning. You can't use it to take pictures.
  10. K_Pugh
    K_Pugh No longer a newbie, moving up!
    Sep 26, 2005
    1,343
    75
    Scotland
    As far as i remember the D70 can only take an exposure of 30 minutes on battery power? I sort of recall something like that from my manual a few years ago - not entirely sure.
  11. invisible
    Mar 10, 2007
    5,213
    977
    Canada
    Garbz, thanks again for your comments. I'm back from shooting and everything you said was verified in the field. In total I took three long exposures: one 30-minute shot and two 10-minute shot. The 30-minute shot is garbage (even with noise reduction). The other two are fine. Maybe next time I'll try your method.
    Well, the long exposures I took tonight total 50 minutes. Prior to that I shot some sunsets, maybe 90 photos. The battery indicator still shows as full.
    Actually there is. I have an MC-DC1 cable release, and I plug it to the camera every time.
  12. PhotoDonkey
    PhotoDonkey TPF Noob!
    May 20, 2008
    167
    South Dakota
    I think this would be the kind of thing that I'd bust out my film SLR for. Digital shooting is great, but there are still some things that film is going to be naturallly better suited for.
