High ISO
Discussion in 'Photography Beginners' Forum' started by scottdg, Aug 19, 2007.
  1. scottdg
    scottdg TPF Noob!
    Aug 7, 2007
    78
    Is there any artistic benefit to using higher ISOs? I know some people may like a little bit of noise in certain situations but I am wondering if there is any use for higher ISOs other than exposure control. I know I have used it in lower light situations when I want to use faster shutter speeds. But are there any situations I would want to use it in bright light?
  2. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    Depends on whether you are talking high ISO for digital or for film.
    With film using a high ISO to get grain can be useful for some images to get a texture or a grittiness. Particularly with B&W. This can give an edge or a quality to an image that works better than fine grain.
    I see no reason why the same cannot be true for digital.
  3. scottdg
    scottdg TPF Noob!
    Aug 7, 2007
    78
    I was speaking of digital. That was the only situation I could think of is to add grain or noise.
  4. am_photoer
    am_photoer TPF Noob!
    Aug 16, 2007
    48
    Missouri
    Digital noise is something to avoid and with bright light you can use a lower ISO. However, i guess there are a few reasons to increase your ISO, maybe from 100-400. That are to 1. allow you to increase your shutter speed more while keeping the aperture around the same. 2. To narrow your aperature while keeping a fast shutter speed --maybe if you arent steady yet or trying to catch alot of motion over a larger depth of field.
    So if you have a desired depth of field and want a really fast shutter speed you can add ISO so you don't have to widen aperture/decrease shutter speed.
  5. scottdg
    scottdg TPF Noob!
    Aug 7, 2007
    78
    Okay. Thanks for the responses. That is pretty much what I thought.
  6. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    If you want a grain type look to a digital photo, you have much better options available to you in post production. You should always use the lowest ISO you can reasonably get away with, but remember; a noisy photo is better than a blurry one. (unless you are intentionally blurring)
