High-quality photo printer
Discussion in 'General Shop Talk' started by Rhys, Mar 13, 2008.
  1. Rhys
    Rhys TPF Noob!
    Jan 26, 2008
    975
    Columbia, SC
    We're looking for a high-quality photo printer. Cost is not necessarily an object as it is a business expense.
    We had a look in Sams and saw the HP 7250 which looked interesting. Our experience with HP and Canon is that Canon eventually gives up printing clearly and starts printing lines across everything despite repeated print-head cleaning operations and full ink cartridges. HP (the C4240) worked well for a year or so and then started tearing up photo paper and not printing well. In fact it now only works on plain paper. The Canon i560 we have has begun not to feed well unless we use plain paper now - as well as the lines issue. We had an Epson a long time ago that also developed a feed problem and prior to that a Citizen. We also went through some Lexmark or other that died fairly soon after purchase.
    So... What we need is a printer that:
    1. Will print high-quality borderless prints on photo paper.
    2. Uses separate ink cartridges for each individual colour.
    3. Works well with generic ink (preferably with refillable ink tanks).
    4. Works well with generic paper.
    5. Works well with a variety of paper thicknesses.
    6. Prints documents nicely.
    Large format printing would be nice but is not very important as we can contract out for that. The use this printer would be put to is quick prints and portfolio work where the time delay in ordering is too much delay.
    Today as an example, the i560 ruined paper because it started printing lines over everything. The C4240 was out of ink so we rushed out and replaced the ink then found it tore the photo paper and when it wasn't doing that, it wasn't fully ejecting the paper and messing up the print on the trailing edge.
    Both printers are headed for the trash as soon as we get a realistic replacement.
    Any suggestions as to what would be good to look at?
  2. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    Look into Epson printers I use the R1800 and find it prints great photos. The issue you are going to run into though is most photo printers including high quality printers are not made for commercial volumes. The R1800 is a great printer if your using it an average amount however I have heard that when used for high volume printing it will break down. I think your going to have to look into commercial high volume printers which are gong to cost more than a high quality low volume printer.
  3. Rhys
    Rhys TPF Noob!
    Jan 26, 2008
    975
    Columbia, SC
    It's not really intended for high-volume work, just for work where time is of the essence such as a quickie portfolio adjustment. I was caught short because I needed a fresh portfolio set and both printers crapped on me at the same time.
  4. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    Michael Reichmann over at The Luminous Landscape, reviews a fair number of printers. You might find some good infor there.
  5. Rhys
    Rhys TPF Noob!
    Jan 26, 2008
    975
    Columbia, SC
    It looks to me like most of the photo printers are very much the same. I'm trying to decide whether to pay more for a printer that'll last several years or just get a cheapie each year and just write it off against tax each year. The Epson R380 looks pretty good as a cheapie.
  6. Rhys
    Rhys TPF Noob!
    Jan 26, 2008
    975
    Columbia, SC
    I have just returned from Best Buy and now have an Epson CX9400 Fax/copier/printer with 4 ink cartridges using Durabright ink. I've seen my in-laws Epson and been impressed by the quality. There wasn't much to choose between them at $80 - $150. I got the most expensive as it was probably the best of the 4. Canon had an interesting little Pixma printer but I think it was more portable than desktop.
  7. atp_design
    atp_design TPF Noob!
    Feb 19, 2008
    75
    from Australia to Belgium
    HP make some very nice hi resolution printers and as stated above Epsom do too. I have extensive experience with HP so i can comment on them but i know like everything there is always a better one out there.
    Look for printers that use UV stable ink.
    Printers that can take thicker stock and a faster RIP software helps. Networkability and remember the consumption of ink vs print output = cost.
  8. skipper34
    skipper34 TPF Noob!
    Feb 6, 2008
    25
    Michigan
    I have run as many as 100 8 x 10 prints per day through the R1800 with no ill effects whatsoever. The rumor about printer breakdown does not apply to the R1800.
  9. NJMAN
    NJMAN TPF Noob!
    Aug 1, 2006
    2,104
    Far beyond the bowels of human existence...Minneso
    Epson Stylus R1800 wide format printer is the one to get. It prints photos beautifully. I have to do head cleanings every so often, and it uses some ink, but then it prints awesome again after that. Its a great printer for professional photos on premium glossy and luster photo paper, and laminates with a gloss coating also.
  10. ksm
    ksm TPF Noob!
    Mar 17, 2008
    93
    I also use EPSON R1800. Great Printer but I'm not sure they are still making it. Kinda sucks because as soon as I bought mine they came out with the replacemrnt R1900, with upgraded inks. Oh well still love the R1800. You can probably still find it for half the cost since the R1900 came out.
  11. skipper34
    skipper34 TPF Noob!
    Feb 6, 2008
    25
    Michigan
    You can still get the R1800 from B&H.
  12. PaulBennett
    PaulBennett TPF Noob!
    Sep 2, 2007
    92
    Oregon
    You didn't mention size but if 8x10 is adequate, check the hp5400dn which prints both sides, uses 4 extra large cartridges, and although not touted as a photo printer, uses their vivid ink doing a fantastic job on photo paper. I got mine for $100 with all the instant rebates.
