High resolution negatives scanner
Discussion in 'Photography Equipment & Products' started by Dandy-Warhol, May 22, 2004.
  1. Dandy-Warhol
    Dandy-Warhol TPF Noob!
    May 16, 2004
    189
    52° 27' 0 N, 4° 49' 60 E
    I'm looking for a negative scanner that can scan at a high resolution to be able to print large formats posters/photos.
    Also a printer that can print these posters/photos.
    Anyone able to point me in some direction?
  2. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    The highest dynamic range available on the scanners in my B&H catalog seems to be 4.8. The resolutions very, but that doesn't make much of a difference when scanning 35mm. There is only so much detail you can pull out of a small negative.
    As if it's a surprise I'm going to recommend the Minolta Scan Dual IV. I have the III. For less than $300 it's got a 4.8 dynamic range and 3200 dpi. No scanner in it's class can touch it.
  3. Dandy-Warhol
    May 16, 2004
    189
    Thanks! Already found it for a reasonable price :)
    all I need now is a printer that can print poster size :)
  4. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    Take a look at the Epson 7600 or 9600.
  5. Dandy-Warhol
    May 16, 2004
    189
    can the Epson print poster size?
    say 20x28 inches? (50x70cm)
  6. aggiezach
    aggiezach Yup...
    Feb 23, 2004
    2,132
    24
    TX
    Here is the link to that family of printers Epson 7600 & 9000
    Kinda pricey, but would be awesome to own! :D
  7. Dandy-Warhol
    May 16, 2004
    189
    The Epson 7600 would be fine and it's not as pricey as I thought they'd be
    :lol:
  8. Solarize
    Solarize TPF Noob!
    Feb 13, 2004
    72
    England
    Just a thought.... what sort of quality are you expecting to get?
    You arent going to get great prints much bigger than A3 when using 35mm film, the negative just wont have recorded enough information.
  9. drlynn
    drlynn TPF Noob!
    Sep 19, 2003
    722
    In the Basement
    Well, that really depends on how the print will be displayed.
    For example Rick Sammons claims that one of his images taken from a 35mm negative was blown up to "30x60 feet for the Kodak Colorama in New York's Times Square."
    A large print may not be tack sharp hand-held, but from 8 feet away hanging on a wall, it may well be plenty sharp, if the original image was sharp.
