High Speed Sync
Discussion in 'Lighting and Hardware' started by saliilp, Mar 31, 2016.
  1. saliilp
    saliilp TPF Noob!
    Mar 31, 2016
    Hi,
    I have purchased Altura Photo Studio Pro Flash Kit for Canon (I have 60D). It has sync speed of 1/250s. Is there anyway, I can take High Speed Sync images using this flash? Any pocket wizard/remote trigger can help?
    Thanks!
  2. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    The light doesn't care what your synch speed is. The shutter does. As long as your camera supports 1/250 then the light will certainly oblige. Using a synch speed that is too high will simply cause a shutter curtain to cover part of your image.
    • Agree Agree x 1
  3. KmH
    Apr 9, 2009
    40,750
    5,588
    Iowa
  4. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
  5. Braineack
    Braineack Been spending a lot of time on here!
    Jun 17, 2013
    11,495
    4,481
    NoVA
    Does the flash support HSS?
  6. Alexr25
    Alexr25 No longer a newbie, moving up!
    Aug 31, 2014
    362
    79
    Australia, near Melbourne
    Going by the info on the Altura web site their APC-958x Pro Flash supports HSS. User manuals for their other flash models don't mention HSS so I would assume that they don't support that feature.
    For HSS to work both the camera and the flash unit must support that feature, if it is not supported by the flash unit then no amount of fiddling with the flash triggering will make it work in HSS mode.
    • Like Like x 1
  7. saliilp
    saliilp TPF Noob!
    Mar 31, 2016
    Hi Fred,
    Thanks for the reply!
    My flash supports 1/250s. Can I take photo with 1/3000s or more to freeze action with that? and if yes, how? The issue is, I don't find High Speed Sync option in my Canon 60D after mounting Altura flash on it. Don't know if I am doing something wrong?
  8. spiralout462
    spiralout462 TPF Supporters Supporting Member
    Dec 4, 2014
    1,069
    493
    On a Canon Speedlight you set the flash to HSS. Then set whatever shutter speed you want in camera. If the Altura supports HSS and ETTL it should be that simple.
    • Agree Agree x 1
  9. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
  10. fmw
    Sep 30, 2006
    3,656
    471
    The duration of the flash will freeze action. Check the specs on the light. It should tell you the full power flash duration which should be 1/1000 sec. or less. If less than full power is needed for the shot, then the duration will be even shorter.
  11. Braineack
    Jun 17, 2013
    11,495
    4,481
    NoVA
    You don't need high shutter speeds to freeze motion when using the flash as a primary source of light.
    • Agree Agree x 1
  12. k.udhay
    k.udhay TPF Noob!
    Mar 6, 2013
    108
    6
    India
    You can do as in this video esp. after 4th minute:
    I assume you want to take a shot similar to this?
altura apc-958x
altura flash high speed sync
