Highlight Tone Priority
Discussion in 'Photography Equipment & Products' started by keith204, Jan 1, 2008.
  1. keith204
    keith204 No longer a newbie, moving up!
    May 20, 2007
    1,643
    Bolivar, MO
    What's a practical use for using Highlight Tone Priority?
  2. Ls3D
    Ls3D TPF Noob!
    Dec 15, 2007
    1,279
    Encinitas Cali
    This is just a semi educated guess, but I believe it is to clamp the whites so as to hold out detail VS just blowing out the detail. Check your manual for more.
    -Shea
  3. soylentgreen
    soylentgreen TPF Noob!
    Feb 27, 2007
    735
    Miami, FL
    Technically, it is suppose to boost contrast in low contrast areas (i.e. white wedding gowns with subtle transitions and the like) I mainly use it when there is a lot of sunlight that washes out certain areas of an image. Dunno if it really works since I have not done a head to head comparison. It does slow down burst mode shooting so I have it as a custom function setting on my 40D when and if i need. Otherwise it is set to off.
  4. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    from what I've been reading...it basically helps to preserve the detail in highlights. I'm not sure how it does it, or if it's better to do it in PP...but that's what it is supposed to do apparently.
  5. Big Mike
    Dec 16, 2003
    33,843
    1,817
    Edmonton
    With digital photography...the ideal exposure may not actually be what looks the best at the time of capture. Looking at the histogram, the ideal exposure is not a balanced graph.
    Actually, for digital photography (and digital editing)...the ideal exposure is one where the histogram is biased toward the right (bright) end of the scale...but without 'clipping' or loosing the highlight detail.
    You can learn more about this by searching 'Expose to the Right'...see HERE.
    From what I can tell, highlight priority mode will give you an exposure that is as bright (or to the right) as possible, without blowing out the highlights. Sounds like a great feature to me.
highlight tone priority with vs without
