Holga 135bc (35mm)
rob91
http://shop.lomography.com/shop/main.php?cat=&pro=hbc
So, to the best of my knowledge, this is a pretty new camera. I'm aware of the 35mm adapter for the holga, but this is marketed as a straight 35mm Holga. I've considered using 35mm on Holga before but my main drawback has been (what I'm assuming to be) a kind of crop in the final image, with 35mm being smaller than 120 some sort of difference between what you're seeing through the viewfinder and the final image. So, what's this new thing? Regular Holga with a 35mm adapter, or a Holga designed to work properly (as properly as a Holga works) with 35mm?
the holga 135 is nice because you can rewind the film without being in a darkroom or shirt. Although the 135 is "actually" well built and therefore lacks the light leaks that cause the funky effects holgas are know for. Expensive from that site, check ebay!
Holga baby! This is big!
the 135 differs from the 135bc because the bc has a mask that gives you the holgaesque vignetting. so if you want holga like shots get the 135bc
you can get the Holga 135bc off ebay for like $45 aus. i think $37 us??
