Holga Film
Discussion in 'Film Discussion and Q & A' started by holga_my_heart, Mar 19, 2010.
  1. holga_my_heart
    holga_my_heart TPF Noob!
    Mar 19, 2010
    Washington
    I was given a Holga for my birthday last November. I was excited to use up my first roll of film and took it to a small business to be developed. When I got them back, however, they were in the normal 4x6 format and it looked like they had been edited. My question is: Is there a certain developing format I should be asking for when I take them to be developed? Or, is it smarter to send off my film to be developed rather than taking it into a photo developers?
    Any ideas or advice is greatly appreciated. Thanks!
  2. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    have them print them 5x5 or 6x6 if they can, if not, find someone else.
    Also, if you can, shoot slide film through it if you get the chance..
  3. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    +1:thumbup:
    this is a square negative and needs to be printed square, which can be done, easily, Well easily by people who know what they are doing.
  4. Vautrin
    Vautrin No longer a newbie, moving up!
    Jun 26, 2008
    927
    58
    It changes
    So if you open the back of your Holga there's a black piece of plastic.
    That's called the "mask" I think, basically it makes sure that the image you take is a nice sharp edge.
    The original Holga was 6cm x 6cm BUT you can also get a 6x4.5 cm mask (more shots per roll)
    So is it square or a rectangle?
    If it's square, it's 6x6
    If its rectangle it's 6x4.5
  5. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    These are, of course, the approximate size of the negatives in centimeters and are rounded up a bit. Also, the Holga, with the mask, does not shoot the modern 6x4.5 format, which is a 15 shot per roll format. The Holga shoots the old 16 exposure format which is closer to 6x4 than 6x4.5.
    It would be appropriate to print a Holga's 16 exp/roll format on 4x6" paper. The aspect ratio is not a perfect match, but close. The modern 15 shot 6x4.5" format is more appropriately printed on 4x5" paper. The square 12 exp/roll format should be printed on square paper. The old common proof size was 5x5" from professional labs and 3.5x3.5" by amateur labs.
