Home-made macro setup for Canon S2
Discussion in 'Digital Discussion & Q&A' started by Xcessiv, Apr 29, 2008.
  1. Xcessiv
    Xcessiv TPF Noob!
    Apr 29, 2008
    Hi,
    I plan on buying a macro flash (not light) for my Canon S2 IS. There digital ones are either really expensive or are LEDs, which I don't want.
    Here's my plan, tell me if it'll work:
    - 35mm camera ring flash with 52mm adapter: link
    - Wireless Optical Slave Flash Trigger with Sync Socket: link
    - Canon S2/S3/S5 52mm adapter from LensMate
    - Raynox DCR-250 Super Macro Filter from LensMate
    My questions...
    1) The macro flash doesn't have controllable power and the Raynox DCR-250 is restricted to a working distance of 4" - 4 5/8". How is it possible to take good macro pictures if the flash isn't controllable and I can't control the distance???
    2) Will this trigger be compatible with the macro flash via the sync socket even if I don't have anything mounted to the hot shoe of the trigger?
    3) Will this trigger be compatible with my S2 IS? In which mode can I disable the pre flash?
    Thank you.
    Regards,
    Yan
  2. Xcessiv
    Xcessiv TPF Noob!
    Apr 29, 2008
    Ok I finally bought the described kit and my brother made some tests. WOW! Amazing results for the price.
    [​IMG]
    You normally need a microscope to see these eyes:
    [​IMG]
  3. tirediron
    Jul 8, 2005
    37,833
    10,893
    Victoria, BC
    Good job.
  4. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    That's awesome. Is that your Yellow Kneed Tarantula? At least I think that's what it is.
    That looks more like a ring light than a macro flash which is often a couple of independent units which allow you to adjust a left / right or up / down lighting ratio.
  5. Rhubarb
    Rhubarb TPF Noob!
    Dec 16, 2004
    286
    Roaming the globe
    Impressive! S/he looks surprised!
+lensmate s5
canon macro setup
flash setup for raynox 250
home made controllable light macro ring flash
home made micro flash
home made set up for macro photography
homemade macro flash controller
macro setting on cannon s2
macro setup
microscope eyes
