Hot Pixels
Discussion in 'Digital Discussion & Q&A' started by teishu, Mar 13, 2007.
  1. teishu
    teishu TPF Noob!
    Aug 9, 2006
    203
    Staffordshire, UK
    Hi, whenever i tak pictures in lowlight i get awful hotpixels covering my picture, why is this ? How can i prevent it. here is an example:
    [​IMG]
    [​IMG]
    Thanks
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I'm not certain...but I believe that longer exposures will bring out 'hot pixels' because of a build up of heat on the sensor...or something like that.
  3. teishu
    teishu TPF Noob!
    Aug 9, 2006
    203
    Staffordshire, UK
    How do photographers get long exposure pics without them ?
  4. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I'm not sure...like I said, I'm not even sure that is the actual problem.
    Noise reduction would probably get rid of the hot pixels...or, it would only take a minute in Photoshop to get rid of them.
  5. teishu
    teishu TPF Noob!
    Aug 9, 2006
    203
    Staffordshire, UK
    well ive spent 20 mins in PS and managed to get rid of most of the visible hotpixels in one of the photos along with a few other alterations. here it is:
    http://www.juphotography.co.uk/juphoto/main.php?g2_itemId=113
    thanks
  6. drgibson
    drgibson TPF Noob!
    Mar 9, 2007
    217
    Directly above the center of the Earth
    If they are always in the same place or if they are on all images then the ccd ic bad. To test this take a normal exposure of a black surface to see if they still show up, if not then it is just digital noice and you will have to deal with them. To me it looks like the ccd is bad and not noise.
  7. astrostu
    astrostu Guest
    Consumer CCDs almost always have hot pixels. Take a picture for 30 seconds or longer with the lens cap on and you'll see 'em.
    For astrophotography, I dark-subtract them out. For practical photography, I usually crop them out, use PS's Dust & Scratches filter, or clone them out. If high-resolution is needed and I don't want to have blurring artifacts from the D&S filter, I would clone them out, or even in the shot of the moon you have, I would just select the moon, invert the selection, and then fill with black.
  8. xfloggingkylex
    xfloggingkylex TPF Noob!
    May 5, 2006
    1,292
    Frederick, MD
    I have a feeling it is a type of noise, or your P&S's sensor is just prone to producing hot pixels.
    Hot pixels aren't what they sound like, they are actually a pixel that is stuck displaying one color, hence being known as a stuck pixel.
