Hot Shoe Question
Discussion in 'Digital Discussion & Q&A' started by hanyo66, Dec 2, 2007.
  1. hanyo66
    hanyo66 TPF Noob!
    Dec 2, 2007
    93
    Go Steelers
    I have a Panasonic DMC-FZ8, and it doesn't have a shoe mount (hot or cold). I have one question.
    Is it possible to build/make/buy a hot shoe?
    I really want to use flashes on cam, but I don't have a hot shoe and I was wondering if there was any way to make one.
    I've searched the internet all night with no avail.
    HELP!
  2. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    You'll have to buy a flash bracket unless you want to epoxy a cold shoe to the body.
  3. hanyo66
    hanyo66 TPF Noob!
    Dec 2, 2007
    93
    Go Steelers
    I'm talking about a HOT SHOE, sorry for any inconvenience.
  4. hanyo66
    hanyo66 TPF Noob!
    Dec 2, 2007
    93
    Go Steelers
    Anyone?
  5. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    According to the Panasonic website, and a few other sites I found, external flash is not an option. Period.
  6. hanyo66
    hanyo66 TPF Noob!
    Dec 2, 2007
    93
    Go Steelers
    That's what I thought, but I was checking anyway.
    It's not impossible, only I guess hot shoe is impossible.
    My digital slave flash works.
  7. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    I would recommend the slide-film trick in order to prevent your on-board flash from flattening your shots. Secure a piece of unexposed but developed slide film (should be opaque) over your on-board flash. The slide film will allow IR to pass but hardly any visible light. This way, you can trigger only the external slave.
  8. hanyo66
    hanyo66 TPF Noob!
    Dec 2, 2007
    93
    Go Steelers
    Ok, sounds good.
    Do you recommend taping it, and will I be able to close my on board flash with the slide film on it?
  9. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    Depends on how often you use the external. If you're using it all the time, it may be easiest just to leave the on-board up with the film taped on there all the time. Otherwise you could tape it on as necessary (though that's a little bit of a pain).
