RPetterson
- Joined
- Dec 10, 2009
- Messages
- 141
- Reaction score
- 0
- Location
- Oregon
- Can others edit my Photos
- Photos OK to edit
* Exposure Time (1 / Shutter Speed) = 1/60 second ===> 0.01667 second
* Lens F-Number / F-Stop = 56/10 ===> /5.6
* ISO Speed Ratings = 400
* Original Date/Time = 2009:12:16 16:57:20
* Flash = Flash fired, compulsory flash mode, red-eye reduction mode
* Focal Length = 400/10 mm ===> 40 mm
* Image Width = 2592 pixels
* Image Height = 3872 pixels
this is the problem, youre shooting at 1/60, and most will say if youre shooting under 1/200, you need both a tripod and a stationary subject.. try bumping up iso, shooting more wide open both in aperture and lens, and off camera or external flash
is there a WRONG ANSWER NOISE BUTTON HERE?!and most will say if youre shooting under 1/200 you need both a tripod and a stationary subject...
on P, many camera, especially indoors with flash in TTL will set 1/60, widest possible apertures, (since they are fixed on ISO) will adjust flash to balance with ambient light.portrait mode
i meant to say when shooting, if youre shooting at UNDER 1/200 without a flash, it will most likely be blurry, did not put it into contextis there a WRONG ANSWER NOISE BUTTON HERE?!and most will say if youre shooting under 1/200 you need both a tripod and a stationary subject...
Where does it say that you need to shoot under 1/200 for stationary? Flash freeze action. If flash reaches the subject it'll freeze the subject's motion. Yes, at 1/60 doing movement/action is a bit tricky b/c motion blur will occur but once again flash freezes action. By your theory, I can't shoot reception at anything less then 1/200s and yet, I'm at 1/125 iso 400, with dance floor at f/8 and background at 5.6 no problem oh and I don't have VR on my main lens.
One of photographers I work for/with, shoot everything at 1/60. Portraits on tripod, everything else in hand and yet again - no problems.
I hate being an @$$ but I'll disagree with you once again. Yank out two 100W bulbs on a night light and take that disgusting yellow diffuser thing that they all come with. Set it near (about 1.5 feet from your subject 45* w/ respect to subject camera line) close enough to illuminate and yet not be in the frame - sure it'll be flat as a wall, but its light. Then readjust the WB. ISO b/n 800-1600 (many older/ consumer models can't really pull that off flawlessly thus B&W is nice with some grain/noise . Shutter speed b/n 1/30-1/80. Lenses she wrote seem like kit lenses - adjust it to 100-150mm (35mm format), it'll probably be something about 50-70 on hers (don't know the crop factor) and shoot it.i meant to say when shooting, if youre shooting at UNDER 1/200 without a flash, it will most likely be blurry, did not put it into context
