How can I achieve very sharp (and detailed) pictures?
Discussion in 'Photography Beginners' Forum' started by a1157814a, Dec 27, 2008.
  1. a1157814a
    a1157814a TPF Noob!
    Nov 23, 2008
    139
    LIke this one?
    High Resolution Wallpaper - Times Square in Manhattan HDR 1024 x 768
    Would using long exposure do the trick?
    Also... if that picture above wasn't at night and I still wanted to get all the details while using the same long exposure time, wouldn't it result it in a too bright of a picture?
  2. rufus5150
    rufus5150 TPF Noob!
    Mar 8, 2008
    1,658
    Austin, Texas
    It's an HDR. A blend of multiple images after which he processes some of the original images back into the HDR for effect. Follow the link on that that you linked to the Stuck in Customs website. He has a full tutorial and explains how he did that image in excruciating detail.
  3. a1157814a
    a1157814a TPF Noob!
    Nov 23, 2008
    139
  4. rufus5150
    rufus5150 TPF Noob!
    Mar 8, 2008
    1,658
    Austin, Texas
    I believe that is also a high-dynamic range (HDR) image.
  5. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    That is HDR, with a good lens, tripod, and sharp manual focus.
  6. a1157814a
    a1157814a TPF Noob!
    Nov 23, 2008
    139
    lol damn...
    well, what general settings could i do on my camera to try to get those type of images?
  7. rufus5150
    rufus5150 TPF Noob!
    Mar 8, 2008
    1,658
    Austin, Texas
    You need to bracket a proper exposure (3+ exposures, 1 on, 1 below, 1 above, if not more above and below). For those images, I'm guessing it was a wide angle and a very narrow aperture (f11+ but I'm just guessing). Then you'll need software to combine the images.
  8. a1157814a
    a1157814a TPF Noob!
    Nov 23, 2008
    139
    no I meant, to try to get those kind of HDR photos without adding putting many pictures together and all that, just single shot.
  9. AlexColeman
    Dec 13, 2008
    1,732
    You can't. You can fake it by using one raw capture, and pushing the exposure to the three gamuts.
  10. a1157814a
    a1157814a TPF Noob!
    Nov 23, 2008
    139
    ok, then what steps can i generally take to get picture with a great variety of colors? I noticed that I could make them more colorful by bumping up the saturation during photoshop but what about during the photoshoot itself?
  11. gob144
    gob144 TPF Noob!
    Dec 6, 2008
    182
    i see these poeple are making it waay to complicated. All you need is a good camera like a modern dslr(usually), A good sharp lens, and a tripod. next you need the photo to be exposed properly and your apature needs to be set on a larger number like f11 and up. take the picture ensuring the camera does not move while the shutter is open so use the cameras timer or if you have it a remote. that should do it with some practise.
  12. gob144
    gob144 TPF Noob!
    Dec 6, 2008
    182
    to get better colour results in the sky and on water buy a cheap polarizing filter for you camera. Also the time of day is important. if the sun is at its highest point in the sky colours will usually be washed out and there will be no depth because of the lack of shadows, so best to shoot in the morning or the evening. i hope this helps
how to get very detailed pictures
