how can i avoid the shadow?
Discussion in 'Photography Beginners' Forum' started by kntrygurl, Feb 18, 2009.
  1. kntrygurl
    kntrygurl TPF Noob!
    Jan 18, 2009
    10
    Dry Creek, LA
    can someone tell me how i can avoid the shadows in these portraits? what settings will i need to use? i have two continuous lights with white umbrellas and a 430 ex flash
    [​IMG]
    [​IMG]
    [​IMG]
  2. Jaszek
    Jaszek No longer a newbie, moving up!
    Oct 7, 2008
    2,177
    31
    Brooklyn, NY
    have the model further away from the backdrop
  3. kntrygurl
    kntrygurl TPF Noob!
    Jan 18, 2009
    10
    Dry Creek, LA
    seriously.....thats all i need to do to avoid the flash?
  4. Mgw189
    Mgw189 TPF Noob!
    Dec 31, 2008
    838
    Binghamton, NY
    You asked about the shadow not the flash. The flash is overpowered. Turn the power down or bounce it off of a wall or ceiling.
  5. Jaszek
    Oct 7, 2008
    2,177
    31
    Brooklyn, NY
    thanlks, forgot to mention that :p
  6. tsaraleksi
    tsaraleksi No longer a newbie, moving up!
    Jun 12, 2007
    1,045
    Greencastle Indiana
    If you want to light images like these, you need off-camera lights without having a light on-axis with the camera. The flash is much more powerful than any other light, and it is not only lighting your background but it is casting that heavy shadow as well.
  7. tinafaecarroll
    tinafaecarroll TPF Noob!
    Jul 8, 2008
    62
    Indiana
    I don't know if you actually wanted a critique or not, but incase you didn't notice, the kids' feet/knees are being "cut off" by the backdrop in all but the last. It's just something I noticed. :)
  8. kntrygurl
    kntrygurl TPF Noob!
    Jan 18, 2009
    10
    Dry Creek, LA
    if i bounce it off the ceiling or a wall its way to bright. if i turn the power done its orange and it don't matter where the flash is pointed. if i take off the flash and switch to manual mode i get blurry, dark, grainy. the highest ISO i used was 400....i was tryin not to get to much grain
  9. Jaszek
    Oct 7, 2008
    2,177
    31
    Brooklyn, NY
    point it back and have a white carboard to bounce it off.
  10. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    Turn the head of the 430EX up and then attach a bounce card...most of the flash will fire in the direction the Speedlite head is aimed but some of the flash will fire in the direction of your subject because of the bounce card.
    A Better Bounce Card
    This web site has good information on how to use the on-camera external flash properly: Flash Photography Techniques
    For off-camera Speedlite use, check out Strobist: Lighting 101 and Strobist: Lighting 102.
    And for help with studio type lighting, check out StudioLighting.net.
  11. nickisonfire
    nickisonfire TPF Noob!
    Dec 24, 2008
    278
    NYC
    depends where you have your flash placed but you could put a reflection card/board to the right to kill the shadows? that might work
  12. Village Idiot
    Mar 20, 2008
    7,274
    406
    Lose the continuous lights. If you want a completely black back drop, move the person farther away from the background. Then move the flash farther from the person.
    If you use the flash off camera with an umbrella, you'll get good results. You're going to need a way to trigger the flash while it's off camera and you should be able to shoot at ISO 100 1/250 shutter speed and about f/9 for good results.
    The farther the flash is from the subject, the more you'll have to turn this up, but that's good because you have more light fall off as the light comes back. This let's you control how much (if any) falls onto the backdrop.
    Same basic theory as in the below link can be applied:
    Zack Arias - Atlanta based editorial music photographer ยป White Seamless Tutorial :: Part 1 :: Gear & Space
