How can this be possible?
Discussion in 'Photography Beginners' Forum' started by Diana, Feb 20, 2008.
  1. Diana
    Diana TPF Noob!
    Feb 20, 2008
    5
    Hello all,
    Hope you can help me with this question, I guess there is a technical answer but since I'm newby on photography I can't figure out why this happened
    About a month ago I took a couple of photos of a project I'm working on the iphone. As you can see on the first photo there is a wall behind the iphone and there is nothing wrong. However, on the other one you can see, on the right side, my reflexion on the wall!!!!
    Needless to say it was the same wall behind and there was no mirror.
    The photo was taken with no flash light.
    Thanks in advanve for your help
    [​IMG]
    [​IMG]
  2. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    Please resize your images, I can't make heads or tails of them
  3. Diana
    Diana TPF Noob!
    Feb 20, 2008
    5
    Sorry, I resized the images and edited the brightness so my reflexion can be seen easily
    [​IMG]
    [​IMG]
  4. Stranger
    Stranger TPF Noob!
    Jul 9, 2007
    495
    i have no idea what this is about... are you complaining because your images are really out of focus or because you can see yourself?
  5. nicfargo
    nicfargo TPF Noob!
    Jan 4, 2008
    369
    Nebraska
    no idea. There would have to be some sort of reflective material for that to happen...either that or you're just messing with us and you did it on purpose.
  6. The_Traveler
    The_Traveler Completely Counter-dependent Supporting Member
    Dec 11, 2006
    18,339
    7,570
    Mid-Atlantic US
    My guess is this:
    Virtually every surface is reflective to some degree.
    In the first shot, your exposure was such that the reflection from the wall was too weak to register on the sensor.
    The second shot was much more exposed and thus even the weak reflection actually registered.
    What color was the wall behind your hand?
  7. Diana
    Diana TPF Noob!
    Feb 20, 2008
    5
    It is light yellow, almost white. "The_traveller": my reasoning for what happened is similar to yours, but what really shocked me is the detail of the reflexion on the wall... you can see the ring in my hand!!!
    Is this phenomenon usual in photography?
    Thanks for your responses
  8. The_Traveler
    Dec 11, 2006
    18,339
    7,570
    Mid-Atlantic US
    I don't know that it is common because this is a pretty unique situation in that:
    • you were close enough to the wall that the reflection actually was bright enough to register. (light diminishes in a ratio of the square of the distance)
    • the shot was dramatically overexposed
    • the object was close enough to the wall and the lens was close enough to the wall that the reflected image hadn't yet become obviously defocussed.
    • people generally dump very overexposed images and rarely post them
    If the wall was glossy, rather than matte flat, that would increase the chances of it occurring.
  9. Fiendish Astronaut
    Fiendish Astronaut TPF Noob!
    Aug 12, 2006
    324
    London, UK
    I cannot believe that a wall can create a reflection so detailed. But there might be something you've overlooked or not mentioned Diana. There is no answer given the information you've given. Could it be a glass door that was open which normally stays closed?
    In these sorts of situations you've got to get out Occam's razor... http://en.wikipedia.org/wiki/Occam%27s_razor
  10. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    To get a reflection you must have a reflective surface.
    The better the reflection the more reflective the surface.
    The reflection is quite detailed as you can even see the front of the camera taking the picture.
    I suspect that the reflection in the second shot is glass - either a door or a window - and you just didn't notice it when you took the pictures.
    If you look at the bottom red line on the 'phone screen you can see that the angle is different in the two images. This means that the PoV is different in the two images (by quite a bit) and the second image has a different background to the first.
    Part of the problem is that the crop is so tight there is very little information from which to draw conclusions. So Occam's razor is the way to go.
  11. passerby
    passerby TPF Noob!
    Jan 21, 2008
    591
    So what actually were you photographing on that wall? Was it something there that need to be captured on your phone?
    It would be beneficial if you can re capture the same wall from different angle with enough lighting to reveal the dark area so we can see the wall itself instead of guessing of what's in there. Request make sense?
  12. MarcusM
    MarcusM TPF Noob!
    Sep 12, 2007
    1,236
    St. Paul, MN, USA
    I think from what she said she was photographing her phone, not the wall.
