How do I do this effect?
Discussion in 'Beyond the Basics' started by JPPLAY, Mar 12, 2004.
  1. JPPLAY
    JPPLAY TPF Noob!
    Mar 12, 2004
    44
    How do I create a picture like this? Is it exposing the film multiply times? I of course would use a tripod so the camera doesn't move.
    [​IMG]
  2. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    You take 6 shots on a tripod with a cable release: one of the background and the rest of the runner. Then cut and paste it together in Adobe PS.
    If this was on one neg/slide then you could either expose for the background or the subject; you couldn't get proper exposure on both.
    If you plan for 6 exposures, then the background must be under exposed by 5 stops every time to add up to proper exposure. The running guy wouldn't even show up probably.
    If you expose properly for the subject, then the background is going to be way over exposed.
  3. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    And you'd be able to see through anything moving (the guy), like a ghost.
  4. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    At 5 stops under exposed probably only his shiney bits would show up.
  5. JPPLAY
    JPPLAY TPF Noob!
    Mar 12, 2004
    44
    Does the first shot have to not include the subject in the picture as I would think you could take the subject and keep taking the pictures and ps them onto the first picture. When you do this in Photoshop how do you make sure you put the subject exactly where he/she should go. I notice these shots alot know mostly for snowboarding so it must be rather easy to ps them.
  6. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    Sure you could use the background from any of the shots.
  7. JPPLAY
    JPPLAY TPF Noob!
    Mar 12, 2004
    44
    So I don't really need to use a tripod for this type of shooting. What kind of speed would I be looking at to take these kind of pictures?
  8. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    As fast as possible. At least 1/250th of a second, and that may be too slow. But it shouldn't be a problem if you shot is set up like this one. Plenty of bright light, and at distances like this DOF quickly equals infinity so you can use wide open apertures to get even higher speeds.
  9. JPPLAY
    JPPLAY TPF Noob!
    Mar 12, 2004
    44
    My camera shoots up to 1/2000. Would you suggest I even shoot that fast?
  10. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    The tripod is only necessary if you want the background to line up exactly in each shot, and it doesn't sound like that's a problem. Just remember to hold the camera still, don't pan with the subject.
  11. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    1/2000th sounds good.
  12. JPPLAY
    JPPLAY TPF Noob!
    Mar 12, 2004
    44
    I usually shoot Kodak 800 iso film. Should I get higher iso film or is this good?
